Bob, I am not expert by any means, but my thoughts are that normally the cast iron cylinder liner is made a "push-fit" into the aluminium cylinder barrel. By "push-fit" I take that to mean that it means it slides in without jamming but requires some effort to push it in, it does not slide in on it's own under gravity or be a "sliding-fit" requiring minimum effort. This ensures that, within the limitations of machined surfaces, the cast iron is in the closest contact with the aluminium in it's cold state as possible.
Now, if memory serves me correctly, the coefficient of thermal expansion for aluminium is about twice that of cast iron, which would lead one to think that the aluminium would expand away from the cast iron. But, the cast iron, being nearest the heat, gets hotter, and quicker, than the aluminium and gets all close and personal with the aluminium. The aluminium, having cooling fins, dissipates the heat faster than the cast iron can transfer it to the aluminium, and so the close fit is maintained.
That is my take on it, no doubt there will be someone to come along and blow it out the water, but I hope it helps you.
Chris
Edited By ChrisH on 23/11/2016 19:50:27
