Fire bricks
Fire bricks
Home Forums General Questions Fire bricks
Viewing 23 posts - 1 through 23 (of 23 total)
  • #410434
    Dalboy
      @dalboy
      Can anyone tell me if bricks from an storage heater are any good to make a silver soldering station.
      Dalboy
        @dalboy
        #410437
        nigel jones 5
          @nigeljones5
          Hi – worst possible use for them. They are made to absorb heat. You need to reflect heat. Ive got a few and its very difficult to solder anything which is in contact with them.
          #410440
            Some of these are what you need, they will reflect heat back at the job
            #410445
            Dalboy
              @dalboy
              Thank you both. I will lokat those Jason thank you
              #410448
              martin perman 1
                @martinperman1
                I've been using storage heater bricks for years and until I read this I've never had problems, I suppose its all down hill from here now sad
                Martin P
                #410458
                not done it yet
                  @notdoneityet
                  Posted by martin perman on 22/05/2019 19:11:31:
                  Martin P
                  When they get up to temperature, they will work OK. But they will have made any metal heating rather less efficient than using the right materials for the job. A larger torch will overcome any heat loss to the bricks. Likely cost you more in gas, than buying the right material, over those (many?) years.smiley
                  #410462
                  Mike Poole
                    @mikepoole82104
                    Vermiculite and Skamolex are a couple of brands that are easy to find from internet sellers.
                    #410467
                    Buffer
                      @buffer
                      Well I use firebricks. Cheap (about £6) easy to get (buildabase etc) heat proof, low thermal conductivity. Stack nicely into a hearth can be left outside. Never had any problem silver soldering with them.  I have seen these vermiculite slabs break easily and break down with bits under the job breaking of and sticking to jobs when the flux and work get hot.
                      Rich
                      Edited By Richard brown 1 on 22/05/2019 20:20:10
                      #410469
                      martin perman 1
                        @martinperman1
                        Posted by not done it yet on 22/05/2019 19:51:06:
                        Martin P
                        I'm pleased to see you find it funny.
                        #410501
                        Bazyle
                          @bazyle
                          It is better to find or buy a Thermalite block which can be carved with a chisel or drilled to help hold things. Just make sure tehy are thoroughly dry if they have been in the rain, Also the ceramic elements from old gas fires work well as supports and are designed to reflect and re-radiate heat.
                          #410504
                          Mike Poole
                            @mikepoole82104
                            I think the performance of vermiculite blocks is excellent but they are quite fragile, if you are silver soldering all day every day then a more durable solution may be desirable.
                            #410505
                            nigel jones 5
                              @nigeljones5
                              low thermal conductivity…..the exact opposite of what they are?
                              #410507
                              bricky
                                @bricky
                                I use thermalite blocks from the builders merchant and you can form pockets in them easily to hold odd items.Works for me.
                                Frank
                                #410521
                                  I think any non combustable material will work, just that some work better than others and may mean you need to use less gas and are able to get the work upto temperature faster which is a good thing.
                                  Beware searching the net for generic Vermiculite or Skamolex as there are many versions available some being denser than other so may not do as good a job as the lower density blocks, also watch the sizes for example you can find blocks for a fiver on the bay but they are a third the size of the ones I linked to that sell for about £12
                                  Yes they are a bit more fragile and the surface can get pulled off when flux sticks to it but I'm still using the ones I bought 10 odd years ago and I do a lot of silver soldered fabrications on my models. Maybe treat them a disposable cost saved in gas will more than likely pay for any replacements or simply raise the work just clear of the bottom sheet/block.
                                  As mentioned in passing by bazyle make sure any hearth material is completely dry especially if stored outside. Once heated any internal moisture will turn to steam and could cause the surface to spall and the last think you want in the middle of that critical final heat is brick in your eye.
                                  J
                                  #410522
                                  Buffer
                                    @buffer
                                    Posted by fizzy on 23/05/2019 00:13:03:
                                    fire bricks are low thermal conductivity on the Vitcas website and others.
                                    Point taken about making sure they are dry but I have never had one spall, they are under an old metal box.
                                    #410550
                                    Keith Hale
                                      @keithhale68713
                                      With due respect to Jason and fizzy, they have both overlooked the big advantage that firebricks and storage bricks have is that they will keep the workshop warm long after you have finished brazing. All that heat put into the bricks and not the work has to be dissipated eventually.
                                      You have burnt the gas, shame not to get any benefit from it.
                                      Stick to light, low thermal capacity bricks and/or kaolin clay blanket folks.
                                      Let's do things properly
                                      Keith.
                                      PS Jason and Fizzy otherwise are spot on!
                                      #410560
                                      Dalboy
                                        @dalboy
                                        Posted by JasonB on 22/05/2019 18:59:19:
                                        On a little bit of a side track from my first post is the company that you linked to. Are they also a good place to buy silver solder from or do you get it from somewhere else.
                                        #410563
                                        Buffer
                                          @buffer
                                          #410600
                                            CuP are a good supplier to use and will happily answer any specific queries, also have a read of their "Best Brazing practice" along the top of the black bar on their website.
                                            #410602
                                            R Johns 1
                                              @rjohns1
                                              I use the storage heater bricks for silver soldering. Whilst they absorb heat they also radiate heat when hot. You can look at this in the same manner as using a charcoal pit for brazing. I start by heating up the bricks then move the flame to the work piece.The ambient heat from the bricks keeps the work hot whilst you concentrate the flame onto the joint being soldered.
                                              The only thing that I have been warned of but not seen for real is to ensure the bricks do not get wet. I am informed that a damp brick having a torch applied to it may explode.
                                              Elmo
                                              #410603
                                                Firebrick is one of those words with two contradictory meanings. There's the type that absorbs heat, and the type that doesn't. What fun the confusion has caused in this thread!
                                                Can anyone think of other examples? For example, bollocks is bad, but the dog's bollocks are good. And I might say of a too hot to touch loco belching steam and smoke, 'gosh that's cool'.
                                                Is there a linguistic name for words that contradict themselves?
                                                Mike Poole
                                                  @mikepoole82104
                                                  An oxymoron covers a pair of word that don’t fit like military intelligence, apologies to military men.
