File sizes
File sizes
Home Forums Workshop Tools and Tooling File sizes
  • #20215
    ron vale 3
      @ronvale3
      ron vale 3
        @ronvale3
        Is there anywhere that supplies files that are either 0.25in or 6mm thick
        Am about to file the expansion link and liiftng link slots in the radius rod
        Whilst the slotting is no problem, i need a file of that thickness to get the ends 'square'
        Or is there a better way i am not aware of?
        #535410
        Grindstone Cowboy
          @grindstonecowboy
          Quick look at Arc Euro reveals these, but there are no doubt other suppliers available.
          Rob
          Links to https://www.arceurotrade.co.uk/Catalogue/Cutting-Tools/Tome-Feteira-Files/Engineering-Files/Flat-Files
          #535415
          Martin Kyte
            @martinkyte99762
            Grind up a triangular file so you have two safe edges either side of the active face maybe.
            regards Martin
            Edited By Martin Kyte on 22/03/2021 12:29:24
            #535439
            ron vale 3
              @ronvale3
              Grindstone
              Thanks Had a complete brainfart fort hem!!
              ^mm will be just the job
              #535462
              Mick Henshall
                @mickhenshall99321
                Had a look at Arc's files, does the length given include the tang or just reter to the file's cutting section?
                Mick 🇫🇴🇫🇴
                #535463
                Rod Renshaw
                  @rodrenshaw28584
                  Can't speak about Arc, but it is conventional to ignore the tang when measuring the length of a file.
                  Rod
                  #535464
                  Mick Henshall
                    @mickhenshall99321
                    Thanks Rod, I am making the filing machine designed by Harold Hall an trying to work out the length of file needed
                    Mick 🇫🇴
