I am fairly new to Model engineering and am looking for some help with run out on my recently purchased ER40 Collet Chuck.
I have checked the spindle run out on my Myford Super 7 at face of the spindle and at the circumference of the shaft. I have zero run out at the circumference and approximately 0.0003" at the face. I have levelled my lathe as per the handbook using a test bar, I recorded a difference of 0.0002" larger on the right side of the test bar.
I bought a backing plate, mounted it onto my lathe and faced it off. I then turned a register to fit the Collet Chuck then transferred the holes from the Chuck to the backing plate then bored clearance holes. After clamping then together, I used a piece of 12mm Silver Steel in a Collet and checked for run out… I can't remember what the reading was but it was quite a way off.
I then decided to turn the register down by 0.020", bolt he two pieces together, insert a DTI into the collet cup and take a reading. I the tapped lightly on one side of the chuck in order to eliminate the run out (a bit like altering a Griptrue chuck). I then traversed across the length of the cup and registered zero run out.
I then inserted the 12mm Silver Steel once again and checked for run out. At the collet face I registered 0.0003" and at 5" from the collet face I registered 0.007". I also carried out the same test using a 16mm parallel test bar with more or less the same result.
The collet set was purchased from RDG Tools. After contacting then they kindly sent me a ball bearing clamping nut free of charge to see if that would resolve my problem… unfortunately it has not.
I would appreciate any suggestions as to how I can solve this frustrating problem.
Regards, Tom
