ER40 collet chuck D1-4
Home Forums Manual machine tools ER40 collet chuck D1-4
Viewing 9 posts - 26 through 34 (of 34 total)
  • #158674
    Oompa Lumpa
      @oompalumpa34302
      John, the "special nut" is about seven squid from Ketan. In the scheme of things this really isn't "yet more money". It is something to make my life a little easier as they don't need Wellie! I would highly recommend them – I have several.
      graham.
      Edited By Oompa Lumpa on 24/07/2014 22:08:23
      Oompa Lumpa
        @oompalumpa34302
        THIS article shows you how to make a collet akin to the Jacobs collet. Okay, it isn't the real thing, but it is close and more importantly, it works. Could make a sort of ER40/Jacobs hybrid?
        graham.
        #158684
        jim’
          @jim11037
          The mention of ARC collet blocks gives me a great idea!!
          I've got some ER32 ones, so, i will stick the hex one in the 3 jaw chuck, chuck some 20mm bar in and see what happens when i turn it.
          Its only through posting and reading all the advice that i've been able to think of trying the obvious!!
          Once again, thank you!!
          #158685
            Posted by Oompa Lumpa on 24/07/2014 22:49:22:
            THIS article shows you how to make a collet akin to the Jacobs collet. …
            Very interesting, Graham … Thanks for sharing that.
            … and I do like his final comment
            jim’
              @jim11037
              Just tried a 20mm collet in one of the ARC/JS collet blocks.
              Yesterday i was turning some 20mm dia stainless (in hard jaws), so same speeds, feeds and same (worn) tip.
              Results are good, not even tightened up overly tight, there was no movement and it cut better than in three jaw chuck. I was running about 60 thou cut yesterday, (.120" off dia). in the ER32, 80 thou was if anything easier going.
              So, i'll order a D1-4 collet chuck, box of collets and a bearing nut and see how it goes. I remain unsure about a six inch dia hand closer on the nut (for now anyway!)
              Once again, i really appreciate the advice, as it got me thinking!!
              I'll post my findings when its all up and runningyes
              #158694
              jim’
                @jim11037
                ordered, so now i await postysmiley
                #158702
                John Stevenson 1
                  @johnstevenson1
                  It'll work,
                  Practice beats theory by about 93.8739346 % [ approx ]
                  #158714
                  Gary Wooding
                    @garywooding25363
                    In theory, theory and practise are the same, but in practise they're different.
                    #158941
                    jim’
                      @jim11037
                      Well UPS came today!
                      Came home from work to a big box of collets and the chuck. I put the chuck on, clocked up less than a thou run, so looking good! I went for the collets that cover up to 30mm and also bought a bearing nut.
                      First experiment was the 20mm stainless bar, I tightened the collet up with a moderate amount of force, cut well, no problems at all.
                      Next up I used some 28mm mild steel and just tightened the nut by hand, gave it a tap and was surprised to see the bar solid. So feeling brave i started to machine the bar and it was solid!! The nut even came undone by hand, so looks like the 6" hand collet closer could be the way to go after all.
                      Big thank you to everyone that gave advice, it really helped.
                      Special thanks to John and Johnyes
