ER40 collet chuck D1-4
Home Forums Manual machine tools ER40 collet chuck D1-4
Viewing 25 posts - 1 through 25 (of 34 total)
  • #12322
    jim’
      @jim11037
      jim’
        @jim11037
        I'm thinking about fitting a D1-4 ER40 collet chuck to my Chester Crusader.
        Has anyone tried one?
        I'm thinking about making up a large hand closer to fit on to a bearing type nut. similar to this type used on jacobs rubber flex
        Any thoughts or advice please
        Cheers Jim
        #158563
        jim’
          @jim11037
          the image didn't work in my opening post
          #158565
          Roderick Jenkins
            @roderickjenkins93242
            Bearing in mind that my experience relates only to ER25: a hand closure might work OK on larger diameter collets that are holding work close to the nominal size of the collet e.g. 20mm diam in a 20-19mm collet but otherwise I think you are going to need more leverage to hold e.g. a 1/4" bar (6.35mm) in a 7-6mm collet.
            HTH
            Rod
            #158567
            Nick_G
              @nick_g
              I was only the other evening watching on youtube a short video about the Jacobs one. I found it quite interesting.
              I am left wondering though if it was the cost of these or them not working as specified that has not made them more popular.
              Here is the link to youtube :- **LINK**
              Regards, Nick
              #158572
              Gary Wooding
                @garywooding25363
                I have a set of ER32 collets for my mill, and purchased the square and hexagonal collet holder (John Stevenson) blocks from Arc Euro. They are great for holding delicate items in the lathe, and the square one can set to run very accurately in the independent 4-jaw. They are also quite useful for quick 2,3,4 and 6 sided dividing in the mill. Maybe they do ER40 versions.
                Just a thought.
                Gary
                Edited By Gary Wooding on 23/07/2014 17:03:23
                #158577
                John Haine
                  @johnhaine32865
                  Yes they do er40 versions.
                  and no, you'll need a wrench to tighten ER 40 collets in my experience.
                  #158579
                  jim’
                    @jim11037
                    That's my thinking John.
                    I was thinking about something 6 inch dia and either pressed on or locking screws to prevent movement.
                    Thank you everyone for the input
                    #158586
                    Oompa Lumpa
                      @oompalumpa34302
                      This would definitely work. However, I did notice, looking at the video linked to above that the collet nut/wheel thing was left hand thread. I don't think this is a deal breaker but you would have to be careful not to touch the wheel when in use or it could turn into an exciting afternoon.
                      Please let us know how you get on as I am going to put this on my (very long now) list of future mods.
                      graham.
                      #158588
                        Jim,
                        Given that your original picture didn't post correctly … this should be a useful reference for anyone interested in what you are planning.
                          'Official' closing torques for ER collets are scarily high, much higher than most of 'us' use. We've been this way before…
                          Roderick Jenkins
                            Posted by Michael Gilligan on 23/07/2014 20:52:39:
                            Jim,
                            Hmm. The "Hammer Blow" is interesting, together with the "internal stop mechanism". Suggests that this mechanism is not just "hand tight"
                            Rod
                            #158602
                              Posted by Roderick Jenkins on 23/07/2014 21:59:25:
                              … Suggests that this mechanism is not just "hand tight"
                              Rod
                              Quite so, Rod … and let's not forget that the RubberFlex collets [presumably] have a "softer" action than ER40.
                              It would probably be worth digging-out some of those patents listed at the end of the instruction leaflet.
                              jim’
                                @jim11037
                                I had never seen figures for closing torque before, 130 ft/lb is a hell of a lot to do with a 6" dia hand closer,
                                here are the figures, i now see why we use sidelock holders!
                                Thank you for further thoughts
                                #158607
                                Roderick Jenkins
                                  To be fair, ER collets were designed as tool holders. ER40 can hold a 1" diameter end mill. Hard steel in a hard collet takes some gripping! As a collet system for a lathe the required torque to hold a job with adequate force will be considerably less. But……..
                                  Cheers,
                                  Rod
                                  #158608
                                    Posted by Michael Gilligan on 23/07/2014 23:04:57
                                    John,
                                    Do you class this as "trying to drag peoples ideas through the mud" ??
                                    John Stevenson 1
                                      @johnstevenson1
                                      If you are work holding as opposed to tool holding then forget the torque figures.
                                      I'd love to put a set of strain gauges in a conventional 3 jaw chuck and measure them when tightened using the standard supplied 5" or 6" chuck key.
                                      I'll bet it's far less than a collet chuck.
                                      It also depends on the design of chuck.
                                      I have a 5" Pratt chuck on my dividing head that is very high geared compared to other chucks and you have to really lean on this to get it to hold without sliding the work back in.
                                      I also have two of the Jacobs Rubberflex and yes they work and work well and from what I can see they will work the same way with any collet in. In fact the Jacobs collet is far weaker in design.
                                      Depending on size they have different numbers of steel fingers, less on smaller sizes, more on larger seperated by the bonded rubber.
                                      All the rubber does is hold them apart, so on say a 1" collet you have a maximum of 12 fingers with an average width of 65 thou max so maximum gripping area is 12 x 0.065 = 0.78"
                                      A 1" ER40 collet has a gripping area of 1" x Pi = 3.142"
                                      I shall leave you to work the maths out on that one.
                                      #158613
                                      jim’
                                        @jim11037
                                        As you point out the surface area of an ER40 collet will be far greater.
                                        This is my thoughts on trying ER40, as they are going to have far more area than hard jaws, (many times i reckon).
                                        I usually just bore soft jaws to hold stuff if it matters.
                                        I will await any more feedback before deciding weather to have a go at this. (most likely willsmiley)
                                        Thanks again for all the advice given so faryes
                                        #158614
                                        Anonymous
                                          Posted by John Stevenson on 24/07/2014 09:42:39:
                                          Hmmmm, according to my maths the calculations given are linear dimensions, not areas?
                                          #158615
                                          John Stevenson 1
                                            @johnstevenson1
                                            Ok so yes linear because I don't know off hand the length to get area but form memory ER40 and rubberflex are about the same, rubber flex might be a tad more.
                                            So for the pedantic we will say 2" for the Rubberflex and 1.5" for the ER40 to give it a fighting chance.
                                            So Rubberflex is 0.78" x 2 = 1.56 sq in.
                                            ER 40 is 3.1412 x 1.5 = 4.7118 sq in.
                                            Ipso Facto – case rests.
                                            Go for it Jim…………………………
                                            #158616
                                              O ye of little faith!
                                              I have a full set of these and use them ALL the time
                                              <edit> it's interesting that the max torque for many of them is less than other manufacturer's recommended closing torque…
                                              Edited By Neil Wyatt on 24/07/2014 11:00:24
                                              #158624
                                              John Stevenson 1
                                                @johnstevenson1
                                                I fully agree Bog's
                                                John Stevenson MBE [ Motor Bike Engineer ]
                                                #158630
                                                  John and John,
                                                  I have absolutely no problem with the "give it a go" attitude, but, given that Jim asked for comments, I think the Jacobs instruction leaflet and [potentially] the patents must be a very "good value" way of learning from others' experience.
                                                  jim’
                                                    @jim11037
                                                    Thanks everyone.
                                                    Think I’ll order a chuck and collet ser over the weekend.
                                                    I’ll post my results, when I have some
                                                    #158672
                                                    John Haine
                                                      @johnhaine32865
                                                      Just to repeat I've got an er40 chuck without a ball bearing closer and it needs a lot of wellie with the collet wrench and a tommy bar to properly clamp, at least when the collet is being significantly closed down in diameter. Life could be easier with a ball bearing nut but actually using a wrench is easy enough, so I don't see any reason why I would want a hand closer or spend yet more money on the special nut. Your mileage may differ.
                                                      Oh and JS's square and hex er40 collet blocks are very nice.
