Er 32 Collets ?
Er 32 Collets ?
Home › Forums › Beginners questions › Er 32 Collets ?
  • #86504
    Packmule
      @packmule
      Im thinking of buying a set of collets but unsure of whether I need a lathe collet chuck ( which seems to make sence to me ) or one with a taper for the headstock shaft ? Its for use on 7 x 14 mini lathe.
      Are the taper ones for mills only? is one better than the other?
      sorry if the question is a bit dumb
      Thanks , Bob
      #6011
      Packmule
        @packmule
        #86508
        David Clark 13
          @davidclark13
          Hi Packmule
          If you use a backplate holder you can put bar right through.
          Use a taper one and the drawbar gets in the way.
          regards David
          #86509
          michael howarth 1
            @michaelhowarth1
            Bob…there is a lot of overhang if the taper type is used in the lathe.
            Mick
            #86510
            martin perman 1
              @martinperman1
              Bob,
              I was given a set of ER32 collets, I looked at making a back plate for my Clarke CL500M but then decided to use a taper chuck similar to your description and then made a draw bar for the lathe. I dont make long parts so it suits me.
              Martin P
              #86512
              Bob Perkins
                @bobperkins67044
                I'm currently considering the same. I was kind of leaning towards a chuck with 3MT to fit the taper in the headstock. My thinking being that this would be more flexible if I changed machines at some time. I had not considered David's point , with a back plate holder I will be able to use it to hold small stock as well as milling cutters. Now leaning the other way ……………. Thanks David
                Bob..
                #86598
                Packmule
                  @packmule
                  Thanks everyone for the reply's, David's answer wins the day as it seems to give more versatility .
                  Now to give the card a pasting . ……lol
