Conventional horizontal and vertical sundials begin to struggle close to the equator where the sun's midday position can be both to the North and to the South depending on the season. Therefore I'm looking at an older design, https://en.wikipedia.org/wiki/Sundial and check out the sundial in the Singapore Botanical Gardens.
The time is read off a semicircular scale with equidistant hours marked every 15 degrees with the gnomon mounted through the axis of the semicircular scale, perpendicular to the same and parallel to the rotational axis of the earth.
So, my question. Is there a way to engrave a scale on the inside of a 40cm diameter curved brass plate? Perhaps someone makes kits?
Thanks, Colin 7.76 deg North
Edited By Colin Whittaker on 07/07/2021 11:50:52
Edited By Colin Whittaker on 07/07/2021 11:53:38
