From a cursory glance at their web site, it looks very much like the Amadeal VM25LV mill, as Jason has suggested. This, in itself, appears to be an progression from the Amadeal XJ-12 mill that I purchased in 2010, upgraded in terms of table size, brushless motor belt drive and the DRO equipment. One hundred pounds cheaper from Amadeal, though. The EMV offering has very similar specifications except the motor power is quoted as 0.75kW against 1.1kW for the Amadeal, but that could be the difference between input and output power. Neither specify which applies. The EMV seems only to be available with an R8 up the spout, Amadeal gives you a choice of R8 or MT3.
I've had good service from Amadeal, albeit some while ago, others on here will doubtless tell a different tale. "Yer pays yer money and takes yer choice"
Edited to remove a 'Larry Phelan' apostrophe.
Sorry, Larry.
Edited By John Hinkley on 21/07/2021 19:40:29
