Posted by JasonB on 13/09/2015 08:05:17:
So as its been about a month since MEW232 came out has anyone got any comments on the results from this little machine that were in my review?
Have any members been tempted to raid the piggy bank?
In a word, no and no.
However, since I had the opportunity to try out the unit a while back I thought I ought to finally extract my digit and write something up. First impressions were good. The machine is nicely made, the instructions are well presented, and I had no trouble getting it up and running. The motor controller is slightly odd in that when switched on the motor oscillates, as if deciding which way to go, before the motor spins up to speed over a couple of seconds.
I didn't try the machine with HSS cutters, as the few that I have that need sharpening were too big. However I did have a range of uncoated carbide cutters in various states of disarray, from simply blunt to having corners knocked off due to operator incompetence.
For the tests I had 2mm and 4mm 2-flute slot drills and several 6mm and 10mm 3-flute slot drills. Where the slot drills were badly damaged I first removed the damaged length using a bench grinder with a 'green grit' wheel.
I found the instructions easy to follow. For some of the larger cutters several passes were needed before all the cutting edges were properly ground. This may be because I hadn't taken enough care when roughing out. I was impressed by the rate at which the grinding disc removed the carbide. I found the 6mm and 10mm cutters easy to sharpen and the fresh cutting edges look really good. For the 2mm and 4mm cutters I had some trouble lining the edges up correctly, so that the finished edges, although properly ground didn't seem quite right? Since I only had one each of the 2mm and 4mm cutters to play with this may well be operator error. I haven't had the chance to try the re-ground cutters in anger, but have no doubt they will be fine.
So in summary the unit does exactly what it says on the tin and is simple and quick to use. It is very good for regrinding blunt, or damaged, ends of cutters. Of course the big question is would I buy one? Probably not, although that is no reflection on the unit, for the following reasons:
1. I tend to make heavy use of the side flutes when milling so the side flutes often end up damaged, more so than the ends. The unit is unable to regrind side flutes.
2. Most of the HSS cutters I use are bigger than the 12mm limit of the unit.
3. I already have a well equipped Clarkson T&C grinder for regrinding and modifying cutters.
