Thanks for the insight John, probably hard for me to justify the cost with the amount of cutters I buy a year and FC-3 ones being relatively cheap.
What method does it use to hold the shanks? is it collets with enough adjustment to allow both metric and imperial shanks to be held or just the common metric sizes?
Also how much does it take off the end per setting. I know its the corner that tends to get lost first with the lighter cuts MEs tend to take but say you had been doing a lot of work with a 3mm depth of cut would you be able to get back to a reasonably sharp edge in one go or would you have to take a few bites at it to get to unused edge?
J
PS Ketan if you are following this are the HSS cutters also available or just carbide?
