Electric bike fault
Electric bike fault
Home Forums General Questions Electric bike fault
  • #596461
    Gary Wooding
      @garywooding25363
      I've had my Viking E-GO folding electric bike for around 6 years now. During that time I estimate I've ridden around 600 miles or – ie. it's not been used very much.
      I used it yesterday and was horrified when the power just switched off almost as soon as I started. I stopped, turned the main switch off and on, pressed the handlebar power button and got power once again. After a 100 mtrs or so the power switched off again. I repeated the original process and all was well again.
      This was similar to something that happened a couple of times a few months ago when I lost power while riding, but pressing the handlebar on/off button fixed it. At that time I phoned Viking who suggested it was a battery problem. I changed the battery but still have the problem.
      Any ideas please?
      Gary Wooding
        @garywooding25363
        #596466
        pgk pgk
          @pgkpgk17461
          Not my area of expertise but game to take a crack at it. 4 likely areas of worry. The switch, but I'd guess that does little more than tell the computer to start up. The 'intdlligence' – assessing whether there is power and more importantly whether the battery pack is balanced. The battery itself as to whether cells are all at a close enough state of function and finally whether motors, bearings etc are causing too much draw.
          If you have access to the individual cells in the pack then you can assess them but if a sealed unit with in inbuilt charge controller your a bit stuffed unless able to test in another bike or prepared to open it up. The switch itself and any resistance to rotation would be easier to assess.
          Pgk
          #596469
          Clive Steer
            @clivesteer55943
            I'm not familiar with the Viking E-Go but when you say the power just switched off did the display, if it has one blank as this would indicate a reset often caused by low voltage. There may be some indicator or protection device in the battery so if there is an overload it protects the battery. Check that the connector for the battery is mating well and the contacts are clean and not corroded.
            CS
            #596473
            Hopper
              @hopper
              If it is 6 years old and hasn't been used much, it could be the battery on the way out. Maybe get it load tested at a battery shop?
              Edited By Hopper on 30/04/2022 11:56:42
              #596475
              Grindstone Cowboy
                @grindstonecowboy
                My suggestion from your previous thread still stands, I'd take bets on the problem being inside the battery pack, and most likely the circuit protection board.
                Rob
                Links to https://www.model-engineer.co.uk/forums/postings.asp?th=174945
                Edit – noted that you changed the battery, but the new one could easily have the same issue.
                Edited By Grindstone Cowboy on 30/04/2022 12:19:20
                #596479
                Pete Rimmer
                  @peterimmer30576
                  I repaired one last year that had a fault in the wheel hub. The owner was compleltely mechanically inept, he was complaining about a loss of speed and range and then it wouldn't work. When I looked at it one of the bearings in the motor hub has disintegrated and bits of the cage has been floating about. and ripped off a hall sensor. I replaced the bearing and all three sensors, plus the well-knackered chain and he was off and running again.
                  I'm not suggesting that you have the identical problem but it might be worth checking in the hub and loom for water/foreign objects.
                  #596481
                  Jouke van der Veen
                    @joukevanderveen72935
                    Above it was said that the bike ran only 600 miles and battery was replaced a few months ago.
                    So, battery should be ok and there is not much mechanical wear I expect.
                    Battery fully charged, computer and electrical contacts ok?
                    #596495
                    Gary Wooding
                      @garywooding25363
                      I charged it a couple of weeks ago and hadn't used it until yesterday. I've swapped batteries. Each battery has a set of LEDs and a push button which is supposed to indicate the amount of charge. Does anyone know the circuit of such a bike?
                      I'll recharge it and try again.
                      #596512
                      Grindstone Cowboy
                        @grindstonecowboy
                        If you have the equipment, I'd recommend testing the battery voltage when it's under load – I used a multimeter, and a 240 volt filament bulb. The battery voltage when charged should be around 48 volts. The LEDs and push button on the battery probably won't show anything useful.
                        Rob
                        #596596
                        John Doe 2
                          @johndoe2
                          In my professional and personal experience, about 80% of electrical and electronic faults are caused by bad electrical interconnections, not the actual circuitry or components themselves.
                          My approach would be to disconnect and clean with switch cleaner spray, (WD40 now do one), as many of the electrical interconnections as you can – ideally all of them – both on the control side and the high current motor circuits. Use an old, clean toothbrush to carefully clean all the connector pins. Allow the connectors to dry out, then reconnect and disconnect a few times to 'wipe' the contacts against each other – all with the battery disconnected.
                          The problem might be in the controller, which might use conductive plastic switches – similar to the sort in your TV remote. These might have got condensation in the switches; causing spurious demands to the controller. They might be tricky to get to and clean. If so, maybe put the controller in a bowl of (uncooked) rice or desiccant, and/or in the airing cupboard for a week.
                          You might have a problem with the battery – but unlikely since you say a new battery does the same thing. Could be the battery internal control board – if you can get to it, clean all the connections as above. Rechargeable batteries usually require a few full charge/discharge cycles to achieve their full capacity; perhaps one or both batteries just need fully charging and discharging a few times – worth a try anyway. If the batteries are cheap, or if 6 years has gone by; individual cells might have become discharged, in which case a battery balancer might help, but only if the batteries and charger are designed to do this.
                          Finally, have a careful visual inspection of all the components and the wiring – something might have got damaged or pinched somewhere.
                          Good luck !
                          Edited By John Doe 2 on 01/05/2022 13:43:12
                          #596616
                          john fletcher 1
                            @johnfletcher1
                            Putting a multimeter across the terminals might show 48 volts or close to 48 on no load, doesn't show you much except the meter is working. All batteries eventually build up high internal resistance such that it is unable to deliver the required current, car and torch type are much the same. What you need to do, is the same test on load and for that I suggest you use 4 X 12 volt X 36 watt car head light bulbs connected in series, any type of fitting will do, so long as they are in working order, I got mine from car boot sales. I use RS contact cleaner, certainly systematically go around all possible connections/terminals. Is it possible for testing purposes only, to connect 4 X 12 volt ex alarm batteries in series, by doing so, eliminating the battery failure ?
                            Our neighbour had to buy a replacement battery for his bike, £600+, the DEALER told him the old one was worn out ???. Incidentally, the very same battery was very much cheaper in Germany but had to be collected. Please keep us posted, as others might have the same problem in the future. John
                            #596682
                            John Doe 2
                              @johndoe2
                              Yes, or simply rig up a couple of wires piggy backed onto the battery supply, so the supply voltage can be read while the bike is operating. Obviously, be careful trying to read your meter while riding the bike !! – build a secure temporary rig that doesn't need to be held or anything to see the voltage.
                              It might be worth knowing that some electric bike companies are taking advantage of the "green" and "eco" revolution and charging a huge mark-up.
                              I nearly bought an add-on electric bike kit, comprising a replacement wheel with an electric hub, the battery and control etc. The company said they normally charged £1,000 but as a special introductory offer, the price would be £500.
                              Some research by myself and my son revealed that the components are readily available from China for a few hundred pounds retail – presumably less wholesale. So I shelved the idea.
                              So I am extremely suspicious about a battery costing £600+ That sounds like blatant robbery to me. If it were mine, I would look into purchasing new cells and re-cell the battery myself. And/or research a good quality balancing or rejuvenating charger.
                              Edited By John Doe 2 on 02/05/2022 10:41:22
