Olaf:
I bought and installed a Newall DRO last year, about October 2011. Different kit as mine was a long bed machine, and I had specific requirements for the diplay mounting arrangements, but the installation of the scales should be exactly the same.
There are some photographs of the original installation of a Newall onto an S7 in one of my albums – not exactly the same as the Newall arrangement, but the photographs show the installation on which Newall based their design.
I have some photographs of the more recent installation, I'll upload them later today, and I also have some Newall piccies as well. I won't upload these as they are strictly speaking Newall copyright, but if you send me a PM I'll send them to you direct. Between them, they should make things clear.
A few points:
Make sure you have the correct scale and guard for the cross slide – Newall sent me the wrong one! They insisted it was correct, but it definitely was not right – too short for a long cross slide machine, would probably have suited an ML7.
The right hand side of the cross slide has to have I think 3 holes drilled and tapped into it, for which the cross slide needs to be removed. It can be done with the slide in situ, remove the tailstock and wind the saddle to the end of the bed for access, but you'll still have to make up an extended drill and extended tap wrench to gain sufficient reach.
When installing the cross slide scale guard, ensure that it sits slightly below the top surface of the cross slide to avoid interfering with anything that might get bolted to the tee slots.
I think (it was only 7 or 8 months ago, but I can't remember – it is said that short term memory goes first!) that the guard for the bed scale is pre-drilled at the same centres as the taper turning attachement holes in the bed. You'd better hope so, as drilling for the bed scale guard is awkward if the lathe is installed backing onto a wall – my S7 was like that when I did the original installation. Definitely a tricky job with the lathe installed backing up to a wall – difficult to position accurately whilst effectively standing on your head, and some drilling machines won't get in there – the larger of my two Makita battery drills was too long, fortunately I had a shorter one that would just do it.
The support brackets for the scales are really easy to use, all should become obvious if you have a dummy run with them. But do take some trouble to get the scales and reading heads properly and accurately aligned so that the head runs freely on the scale and doesn't impose any side loading on it – it'll be ok if it's free at both ends of it's travel, but do check carefully as the scales don't like being bent.
Also, take some time to think about where you mount the display, and how you run the cables to it. Avoid leaving them just hanging loose in the mud, blood and swarf, they would get very messy as time goes by. And you don't want them somewhere you can drop chucks, faceplates, vertical slides etc. on them – replacing a cable means replacing the reading head, and that's not cheap.
Funnily enough, replacement scales are relatively cheap – I damaged one of about a metre length installed on my milling machine, it was only GBP80 to replace it, I had expected much more, and it arrived within a couple of days. On the upside, I now have a very good supply of precision 5mm diameter steel balls!
Other than that, installation is straightforward. Any questions, send a PM.
