I fail to see where your coming from and the logic Sid.
Two spanners to find and pick up against one. Undo and remove the collet nut, every time a different collet needed, remove collet from nut and put back replacement in, then of course the reverse not less than 45 secs.
Not to mention the extra loading on the bearings and cutter dropping and thats with Wabeco supplied ER even worse the chinese ones. Should i mention the lost height.
R8/MT3/2 looking at collet change and cutter in less than 20 secs with undue loading on bearings.
Lawrie i still have my round column as a backup 7 1/2 years on. When i used to use it i left a socket and ratchet by the side. Just have to plan your workload height if want to retain centre, thats the key thing.
Must admit i did mill away a few times without tightening much the same effect as when a vice breaks.
Think i flashed over 20″+ by swinging the head round.
The problem with dovetail columns is seemingly never enough tension on the gib strips with around 200kg hanging off, the column dont flex nothing like a Wabeco but theres definate movement putting a cut on. Swings and roundabouts.
