Drawing Projections
Drawing Projections
Home Forums Beginners questions Drawing Projections
Viewing 25 posts - 126 through 150 (of 172 total)
  • #264871
    Paul Jarvis 2
      @pauljarvis2
      The trapezoid shape is representative of a frustrum of a cone and is the side elevation or main view of the drawing
      The rule I was taught when in the drawing office is very simple,
      For first angle projection view the side elevation from the right hand side and draw the resulting end view on the left hand side of the side elevation( i.e view through the object)
      For third angle projection view the side elevation from the right hand side as before and draw the resulting end view on the right hand side of the side elevation.
      The same rule applies for the plan view.
      Paul
      Brian H
        @brianh50089
        Quote; "W J Hall
        9 forum posts
        As someone who was at school before metric became standard I have never really mastered cms, despite doing O-Level early enough to encounter CGS
        I'm glad it's not just me, I don't understand cms either and I have to convert them to mm 's before they make any sense.
        #264950
          Only dressmakers use centimetres, bless 'em!
          #264952
          Jeff Dayman
            @jeffdayman43397
            Duffer – Not just dressmakers, respiratory therapy people too – I recently had some tests done and the pressure in the therapy was expressed as "centimetres of water column" in a manometer. JD
            #264953
            V8Eng
              @v8eng
              Posted by SillyOldDuffer on 05/11/2016 18:41:54:
              Furniture Stores use centimetres.
              I have then to convert them to imperial measurements for the wife who does not do metric!
              Edited By V8Eng on 05/11/2016 18:53:43
              #264957
                Posted by V8Eng on 05/11/2016 18:49:22:
                My stepson is a kitchen fitter. Oh how we have laughed when his insistence on millimetres collides with my DIY centimetres…
                V8Eng
                  @v8eng
                  A Model Engineer using centimetres?crying
                  #264959
                    To my surprise … That lovely Swiss pantograph that I'm tinkering with is calibrated in centimetres.
                    Edited By Michael Gilligan on 05/11/2016 19:24:23
                    #264967
                    Ajohnw
                      @ajohnw51620
                      Many areas in Europe use cm's and other divisions and take no notice what so ever of what ISO say. There reason is simple – how for instance can something be about 150mm long as mm are rather small. About 15 cms makes more sense but some might say about 1 1/2 what ever the 10cm unit is – I can't remember. Prior to ISO's stupidity I would have had no problem remembering what they were at all. ccs went the same way but are still widely used.
                      TSH
                        @tsh73987
                        > It took me a while to work out that it was graduated in Decimetres, the only example that I have uncounted of this multiplier being used.
                        Quite so. But for further examples of the use of multipliers which are not powers of 1000, look no further than meteorology. I expect most of us are used to the millibar, but this is now a deprecated term and the replacement is exactly the same size, but with a brief nod to the SI unit of pressure (the pascal). It is the hectopascal (hPa). This has even infiltrated into aviation where one might hear on the radio that the QNH is 990 hectopascals. (QNH is a shortform code for the pressure at sea-level).
                        As if that weren't enough, a chart of the upper air will have height contours labelled in decametres (abbreviation: dam).
                        Here's a chart with both together!
                        Trevor
                        PS In case you are wondering what 'Thickness' means: in this case it is the 1000-500 hPa thickness which is the vertical distance between where the pressure is 1000 hPa and where it is 500 hPa. It represents an average temperature in that layer of the atmosphere.
                        #264981
                        Ajohnw
                          @ajohnw51620
                          I'll always remember the apologetic mention of sorry folk we now have to talk tonnes per m^2 and can't use tonnes per cm^2 any more. Frown – ISO say so.
                          The problem is down to visualisation again. Easy to look at sensible things and thing tons per inch^2. Not too bad to think in terms of tonnes per cm^2 but 1m^2 is just too big, May as well use hectares or square kilometers.
                          Doesn't matter didley squat when calculations are done but does when it comes down to rough visualisations.
                            OK, I was completely wrong about only dressmakers using centimetres.
                            Everyone knows that dressmakers use inches. Of which there are 30 to the metre:
                              Where did you get the tape, Dave?
                              … Slimmers' World ?
                                Posted by Michael Gilligan on 05/11/2016 21:16:49:
                                … Slimmers' World ?
                                Busted again!
                                #265026
                                Ian Abbott
                                  @ianabbott31222
                                  I still refuse to believe that one-thousand-four-hundred-and-thirty-five-point-one millimetres is easier than four foot eight and a half. And a one-thousand-two-hundred-and-ninteen-point-two by two-thousand-four-hundred-and-thirty-eight-point-four millimetre sheet of plywood is easier than a four by eight. Especially if you need to cut it into four equal widths of shelving.
                                  And how mad is a fifteen-thousand-two-hundred-and-forty-millimetre long room, rather than a nice even fifty feet. I see this on architectural drawings. Can anyone really visualize fifteen-thousand-two-hundred-and-forty-millimetres. Fifty feet is easy. Sixteen and a half yards / fifteen and a quarter metres even.
                                  And don't get me started on Americans and 'millimeters' et al.
                                  Ian
                                  #265030
                                    Off-topic, I know … but here is an interesting tape measure: **LINK**
                                    http://www.pitape.co.uk/aboutus.asp
                                    Ajohnw
                                      @ajohnw51620
                                      The answer to about 666mm problem is to always follow it with a tolerance. About 67cm isn't much better.About 6 1/2 of the units I can't remember is probably the best one. I chose 666 as it's the number of the devil. It's also about 2ft.
                                      Sam Longley 1
                                        @samlongley1
                                        Posted by Ian Abbott on 05/11/2016 22:25:13:
                                        Ian
                                        You would not, you would use millimetres & metres,( which are the correct units to use in the building industry,) hence for the last one you would say 15.24 metres
                                        As for your sheet of ply you will notice that it is not 3/4" thick etc it is 18mm etc
                                        I would further suggest that you try working out the area of 4 ft 12 15/32" multiplied by 2 ft 6 3/16"
                                        Then perhaps you might welcome the introduction of the metric unit.
                                        Fortunately my training started just as metrication in the building industry was introduced because it drove my father mad trying to teach me duo decimals
                                        #265056
                                        Chris Evans 6
                                          @chrisevans6
                                          I am late to this thread re 1st and 3rd angle projection. We had a draughtsman who regularly used both on the same drawing and could not see his errors. We got used to it in the toolroom and didn't bother trying to correct him as there was no hope.
                                          Sam is 4ft 12 15/32" 5ft 15/32" in my book ?
                                          #265084
                                          KWIL
                                            @kwil
                                            Micheal,
                                            I note with interest the Pi Tape is 1/2" wide and 0.25mm thick.
                                            #265108
                                              Posted by Ajohnw on 05/11/2016 23:17:48:
                                              I hope you are not basing your kitchen on 666mm being "about 2ft" you may get away with thinking 600mm is 2ft but 666mm is just over 26"
                                              #265154
                                              Enough!
                                                @enough
                                                Posted by Chris Evans 6 on 06/11/2016 08:32:41:
                                                Then he wasn't a draughtsman (though he may have been masquerading as one). No more than a toolroom person who uses his micrometer as a c-clamp can be called a toolmaker (yes, I've seen it and yes it was lightly clamped and quite temporary, but nonetheless ….).
                                                #512621
                                                Paul M
                                                  @paulm98238
                                                  I have read through these posts and found them interesting.
                                                  I went to secondary school during the 60's and was taught 1st and 3rd angle orthographic projection. We worked primarily in imperial for all our measuring in all subjects. It was not until I was teaching during the 70's that metric was introduced and was taught. The transition was gradual and costly having to convert machines and all measuring equipment. Buying stock was interesting as metal remained in imperial sizes for quite a few years and again was gradually replaced by metric sizes.
                                                  I consider myself lucky in that I have no issues working in either metric or imperial apart from refusing to accept a centimetre as a valid way of expressing a measurement. I enjoy the mental mathematics when converting from one to the other. A bit like being married to a French lady – some conversation is in French some in English with the occasional use of a dictionary.
                                                  #512636
                                                  Peter Howell 1
                                                    @peterhowell1
                                                    I agree with PaulM's comments. I must be a similar age to him and have no difficulty with either 1st or 3rd angle (providing you are told what the drawing is in) or metric / imperial. I sometimes use either. If I've measured something and it looks better (more rounded) in inches whereas it would be odd amount in metric I'll use inches. This particularly applies to DIY building jobs where accuracy in not so important so long as it fits.
                                                    I also avoid cm, never seen the point of them – they only add to the confusion.
                                                    My mantra for 3rd angle was "What you see – Where you see it".
                                                    #512727
                                                    old mart
                                                      @oldmart
                                                      The drawings we used for Airbus, Westland, BAE usually had the projection symbols on them, but I cannot remember whether they were first or third angle.
