John, you beat me to it! But I would just query one thing with you. The DOL switch on my lathe was re-arranged for both single phase and three phase simply by re-arranging the internal wiring. The contactor coil was connected across one of the three phases and neutral, this being equivalent to a single phase circuit. No need to mess around removing turns of wire.
Otherwise, they can indeed be easily dismantled & reassembled. In my case, the coil failed, so I replaced the coil with a plug-in mains relay and rebuilt the insides to give the same facilities.
An edit: Yes it is worth it for the NVR function alone.
Peter G. Shaw
Edited By Peter G. Shaw on 25/04/2019 21:09:22
