Wow, you draughtsmen sure know how to lay into something don't ya.
Apart from Julius's non conventional way that does not adhere to the TD standards you have known and have loved for all these years, I reckon they are quite readable and quite easy to understand. Take part 33 for example: if the 3d image was not there then I would have scratched my head over that for a lot longer than I did. Having the 3d image there I was very quickly able to determine what the drawing for that part was all about. I looked at a few other components on that sheet, and again, all pretty intelligible.
I think the info you need must be all there. Once you get your head around (and into) his methods of presentation you should be ok I guess. Yeah, if they landed on the desk of any serious engineering company then they would be laughed at, I can see that,. But for home hobby use, they look like they would get the job done.
I've been seeing his drawings for quite a few years now, they are all over the internet. I'm sure if I found an error on one of his and reported it, then he would correct it quite quickly. This can't be said for many of the model engineer drawings that are kicking about and which are continually getting sold over and over again with the same mistakes in them, never corrected even though the errors are much talked about.
So, bearing in mind this is a hobby drawing, and apart for the unconventionality of JDWs drawings, what is so bad about them? Why is the drawing in question so disgusting and only fit for bog paper?
Steve
Edited By Steven Vine on 17/08/2016 18:55:50
