D profile tube
D profile tube
Home Forums General Questions D profile tube
  • #25594
    John Chapman 5
      @johnchapman5
      John Chapman 5
        @johnchapman5
        Help needed
        I'm restoring a vintage car, the hood frame uses D profile tube, the size is 22mm x13mm, the original tubing has corroded and is not salvageable.
        I have searched the net for D tube but can't find any this size.
        If I acquired round steel tube, is it possible to profile it by using a swager with the correct dies.
        If so, what type of tubing should I purchase?
        Any help would be much appreciated.
        #324112
        pgk pgk
          @pgkpgk17461
          I know it's not purist but couldn't you just run a router bit down the sides of some ally bar of near size to create that D.. assuming it's painted anyway no-one will know and it'll last longer.
          #324118
          Brian H
            @brianh50089
            I seem to remember that the K N Harris boiler book shows a tube with a flat down one side. OK so that was in copper but I think the same idea would work in steel.
            He bored a hole in a wooded block and then milled a flat on one side to give the correct amount of flat and then hammered or pressed it down to the level of the wood.
            It seems to me that that would work in steel in the sort of gauge you would expect to find on a car.
            #324130
            John Reese
              @johnreese12848
              You should be able to shape round tube into a D. One method would be a grooved roller opposite a flat faced roller. Another method would be straight dies, one grooved to the contour of the tube and the other flat. The tube would be pressed between the dies, advanced and pressed again. In either method I suspect the tube will be bent and will need straightening. Getting the right sized tube to get the finished contour you wan may be a problem.
              #324149
              Clive Foster
                @clivefoster55965
                In principle such re-shaping is possible with fairly simple tooling providing the circumference of the finished D profile is little greater than that of the starting tube ensuring the tube is never in compression during the re-profile as such would almost certainly cause ripples. $6,400 question is how much larger does the finished profile have to be. I imagine you'd need to do the job in 3 or 4 passes, annealing if required. Difficult bit looks to be pulling neatly round the relatively sharp corners at each side of the flat.
                Another point not to be overlooked is figuring out what material to start with. Need something soft and unstressed, cold drawn tube being very unsuitable. Unfortunately almost every application for ordinary tube requires stiffness so a bit of work hardening is acceptable and pretty much par for the course. Generally just needs to be workable with Hossfeld benders and the like.
                #324191
                vintagengineer
                  @vintagengineer
                  What size D section are you trying to make?
                  #324195
                    Posted by John Chapman 5 on 28/10/2017 15:14:19:
                    vintagengineer … ^^^
                    #324208
                      Is there a visible seam in the old tube? could it be folded from sheet around a "D" shaped former and then slide the former out.
                      Former could be pre bent if there is a gentle curve to the tube and use solid material bent for the corners as it would not be easy to tightly bend the folded tube.
                      #324245
                      Nick Hughes
                        @nickhughes97026
                        Have a chat with these guys:- **LINK**
                        #324278
                        Jonathan Garside
                          @jonathangarside40968
                          http://www.vintagecarparts.co.uk sell 19mm x 10mm D shaped steel tubing
                          Jonathan
