Cutting oil
Cutting oil
Home › Forums › General Questions › Cutting oil
Viewing 8 posts - 26 through 33 (of 33 total)
  • #240804
    Dan Carter
      @dancarter89683
      David,
      Another interested customer here.
      Dan
      #240805
      Muzzer
        @muzzer
        Me too – I could manage 2 or 3 litres if that would help. I assume the price makes sense.
        Murray
        #240897
        Clive Haynes
          @clivehaynes74488
          Modified the nozzle on the lathe coolant pipe and the neatcut does now trickle out which is okay for me as I do not want it gushing out. Took the pump out from the mill and it looks like the gauze on the suction is to fine, so I will look for an alternative gauze and give it a try.
          #240940
          John P
            @johnp77052
            Hi Clive,
            I don't have any gauze or screen on my coolant pump intake it would
            be a bad place to have it whatever type of coolant /cutting oil
            used as the small area can soon become clogged.
            I have 4 machines which use the neat cutting oil and all of them
            have a primary catch tank to trap washed down swarf, the oil travels
            over a weir then into the bottom tank which remains clean.
            With your Warco HV machine it has a very small tray at the base
            much the same as my mill ,i use some made up extension wings
            to catch overspills i think you would probably need something similar.
            An overtray could incorporate a primary catch tank and would avoid
            a difficult job cleaning out the main coolant tank .
            As Nick_G posted.
            "I find that if a good quality soluble is used the water evaporates away
            and leaves a nice thin film of protective oil on the machine".
            This or course does not take account of the evaporated water that
            has disappeared into thin air only to magically reappear now completely
            devoid of any rust inhibiting properties on every metal object .
            As Neil Lickfold posted
            "Clive, the best and longest lasting machines I have worked on, never used soluble oil on the machines.They used straight cutting oils, that were thin
            like a honing oil. The machines that used soluble oils had wear in them as to the almost new condition of the cutting oil machines. I'm a convert of
            using oils and not water based coolants now ".
            I would agree with that ,my Warco lathe i have had for eighteen years and
            has used neat cutting oil in all of that time ,the slideways are still like new.
            If you go with cheap coolant, ie soluble coolant and by cheap i mean
            on a volume by cost basis it could be dearer in the long run.Just recently
            a thread on a Myford 280 lathe the owner seems to be faced with a with
            a bill for about £900 .00 to have the bed reground ,whilst we don't know the
            history of the machine the most likely cause is poor maintenance / lubrication.
            Clive Haynes
              @clivehaynes74488
              Hi John,
              I note that my lathe does not have any gauze, so good point. My mill does have an extended tray with large wings as you describe, it came with the machine. I have drained the coolant tank at the moment and am trying to research a low viscosity cutting oil without much joy. Millers and morris oils do some but in large quantity's, Sure Chemicals do 5ltr sizes but no specs and they recon it stinks. I have even thought of mixing the neatcut that I have with sewing machine oil which is thin and relatively cheap. I do not want to go the coolant route.
              #240991
              John P
                @johnp77052
                Hi Clive,
                Couple of photo's in album Workshop and machines ,of
                J & L advantage flyer for June Exel suds pumps on offer
                and from the from the May edition Exelcut 401 neat cutting oil
                the price ends for this June 10th works out about £3 a litre
                inc the vat ,i don't know if this will be thin enough for your
                requirements i have used this for years and found it
                to be ok.
                John P
                  @johnp77052
                  Hi Clive,
                  Have sent you a pm.
                  Jon
                    @jon
                    £15 here for 5Ltrs not £19.5 for 4 Ltrs **LINK**
                    Works out cheaper than J&L rip offs VAT added plus delivery.
                    Currently low on Castrol Cooledge BI got 20Ltr cheap last year about 2Ltr left, found no difference to Smith and Allen and other cheapy stuff from local tool merchants all leave an oil residue when water evaporates and don't stink. Just need topping tank up about 4Ltr of water a week same as any other, more now warmer weather.
                    Did have a session last year with 5Ltr fully synth but couldn't get on with an opaque liquid coming out even though was doing the job.
                    Neat I will use for tapping 30% of the time that's about it, coolant is used with more force to clear debris. Neat and coolant will splash the same so no argument. At least with coolant can wash machines down and leave an oil residue.
