Cross-slide movement naming?
Home Forums Manual machine tools Cross-slide movement naming?
Viewing 15 posts - 1 through 15 (of 15 total)
  • #12351
    OuBallie
      @ouballie
      In – Out, Back – Forward,
      OuBallie
        @ouballie
        'End of World still Nigh' but need to keep myself occupied while waiting.
        I have fitted two DPDT 3-position toggle switches to the FeedRodMotor remote station;
        1) Left/Off/Right for the Saddle movement selection,
        2) ?/Off/? for the Cross-slide ditto, but how to label it is the question.
        Is there a standard for describing the movement?
        The 'net has a selection as usual.
        The same applies to the Y-axis on a milling machine as well.
        This is something I've never bothered with beforehand, but pedant gene is being awkward and in a huff right now.
        Geoff – How long does a %#*+ head cold last?
        #163512
        Ed Duffner
          @edduffner79357
          How about?
          – Advance / Off / Retard
          – Plunge / Off / Withdraw
          – Advance / Off / Withdraw
          – In / Off / Out
          – Cut / Off / Back-Out
          – ^ / Off / v
          U+2191.svg / Off / U+2193.svg
          smiley
          #163515
          Peter G. Shaw
            @peterg-shaw75338
            I would say "In-OFF-Out" because for most jobs, one moves the the tool "in" to make the cut, and "out" at the end.
            Advance, Retard, Plunge all seem to imply a different type of operation to me, although they could apply here. Cut, Back-out & Withdraw would be be more applicable I think than the first three, but overall I would go for the In-Out option.
            I have read at least one author talking about "putting the cut on", but I don't recall taking the cut off.
            For milling, I would use Forward-OFF-Backward as in Forward = away from you and Backward = towards you. The trouble with milling is that cutting can take place equally well in either direction, whereas in lathework, most work involves either doing something to a longitudinal external diameter, or facing a disc. Cutting an internal diameter does involve cutting the other way round, but in my limited experience is less often done.
            Peter G Shaw
            #163517
            David Colwill
              @davidcolwill19261
              I would say X- (slide moving away) off X+ and Z- off Z+ but that's just me crook .
              David.
              #163520
              colin hawes
                @colinhawes85982
                The convention used for CNC programming is left-to right axis -X table moves to left…….+X table moves to right
                in and out axis -Y table moves out (towards operator)
                in and out axis +Y table moves in (away from operator)
                Vertical axis +Z tool moves up …………..-Z tool moves down
                That's the way I remember it anyway so the cross slide on a lathe would be +/- Y. Colin
                #163531
                Anonymous
                  What Colin describes is true for a CNC mill, but is not true for a lathe. The convention for a CNC lathe is cross travel is X, axial travel is Z and live tooling is specified as the C axis.
                  #163542
                  colin hawes
                    @colinhawes85982
                    Andrew. thank you for the lathe axis description I've only worked with CNC machining centres so I am pleased to learn a little more. It's a useful forum. Colin
                    #163543
                    jason udall
                      @jasonudall57142
                      On lathes also x+ leaves more metal as does z+…the z axis is generaly “common” to mills..the pseudo y axis for live tooling/milling is a interpolation of x and c axes…the z y plane can also be programmed “wrapped” round the part…again a interpolation of x z and c..lathes with y axis do exist but these are generally deemed machining centers and these have many axis not conveniently named
                      #163617
                      OuBallie
                        @ouballie
                        Thanks for the responses guys, much appreciated.
                        As usual, the mind boggles at the way English can be used to describe something in a multitude of different ways, and all meaning/describing the same thing.
                        I will give Ed's arrows a try first, and see how I get on with them.
                        Geoff – Head cold clearing, so End of World NOT Nigh
                        #163625
                        jason udall
                          @jasonudall57142
                          Arrows point ing in the direction of motion…
                          Yep…no need to remember what it means..so at a moment of stress no chance of error. ..all good
                          #166150
                          Howard Lewis
                            @howardlewis46836
                            With the Common Cold, the rule is:
                            If you do nothing, it will go after seven days. If you take medication, you will be rid in a week!
                            I favour the ideas of arrows, unlikely to be misunderstood.
                            #166152
                            Howard Lewis
                              @howardlewis46836
                              #166171
                              OldMetaller
                                @oldmetaller
                                I now have The Hokey Cokey as an earworm…sad
                                D'oh!
                                John.
                                #166175
                                Oompa Lumpa
                                  @oompalumpa34302
                                  Posted by OldMetaller on 10/10/2014 08:04:06:
                                  D'oh!
                                  John.
                                  I am not impressed John.
                                  You have now given it me.
                                  Bugger.
                                  graham.
