Cordinate problem.
Cordinate problem.
Home Forums Beginners questions Cordinate problem.
  • This topic has 8 replies, 4 voices, and was last updated 6 May 2012 at 08:15 by Raymond Anderson.
  • #6131
    Raymond Anderson
      @raymondanderson34407
      #90272
      Raymond Anderson
        Helllo all,
        Could anyone out there who has a grasp of trig help solve my problem which is as follows,
        I have a piece of steel 50mm in length, now 44mm in from the end I drilled a Ø3mm hole to act as an axis of rotation, then 10mm from the axis is a small center mark I need to rotate the piece by 50deg left and right so when I rotate the first 50 deg what should the dro be showing to get back exactly over the center mark, in other words what amount do I need to move the x and y axis to get back right on the center mark. I have zeroed the x and y over the axis. I come up with figures of 3.57 and 7.66 but I am not to confident about my calculations.
        Raymond.
        #90276
        Mike Wainwright
          @mikewainwright87512
          Raymond
          Can you do a quick sketch so I can understand exactly what you are doing and I will check your dimensions
          #90277
          Peter Tucker
            @petertucker86088
            Hi Raymond,
            I get 6.43 and 7.66 but could be mistaken abut what you are doing, a diagram would help.
            Best of luck.
            Peter.
            #90278
              I get the same figures as you 6.43 on the Xs and 7.66 on the Y.
              J
              #90279
                You should also be able to use the angle function or even set a one hole PCD on your DRO which will give you the position that the ctr mark should be in, thats assuming you have a proper job not just individual readouts.
                J
                Edited By JasonB on 05/05/2012 20:32:11
                #90291
                Mike Wainwright
                  Did a quick sketch in Autocad and I agree with 7.69and 6.43
                  Tried to paste the sketch from autocad but failed.
                  #90292
                  Raymond Anderson
                    Hello All,
                    Many thanks for the reply's to my question. I tried to upload a drawing from the Solid edge model but no joy.
                    You all seemed to have grasped the situation from my description, so I will crack on using the figures of 7.66 and 6.43 as it is not too critical as long as the angle is 50 Deg.
                    Jason, Yes the dro is a Newall 3 axis C80 not individual units. So I will also see what it comes up with.
                    Regards to all,
                    Raymond.
                    #90293
                    Raymond Anderson
                      Update, I have managed to put a jpeg into my album, the sketch is from another programme as this site software can't handle the drawing from the Solidedge model. It is from the solidedge model that I got my original figures of 3.57 and 7.66
                      Raymond.
