For anyone tempted to dismiss the risk of battery explosions, THINK AGAIN
As already said, a Lead Acid battery that has been charged will have produce a mixture of hydrogen and oxygen.. If any heat source, flame or spark is applied, even inadvertently, it will ignite the mixture and there will be an explosion.
I have seen it happen, fortunately on a small scale.
Lord De Lisle and Dudley retired and bought himself a boat. Having charged the batteries, he checked the acid level with a naked flame. It put him in hospital for some time.
Treat any battery with great respect. A vehicle battery, apart from the explosion potential after charging, and the sulphuric acid content, can deliver a current several hundred amps
The starter motor can have a current draw, on cold cranking, of over 400 Amps
The winding are usually copper strips. so not designed to minimise current flow, rather the reverse..
You can electric weld with about a tenth of that, so be warned.,
