I hope somebody can help, I was using the tailstock on the Colchester Triumph 2000 to do some deep hole drilling, I took the quill to full depth, it then became jammed up tight, very difficult to wind back in and out.
I've taken the tailstock off of the lathe and tried to remove the quill from the tailstock body to give it a clean. I suspect some swarf has got in somewhere.
Can somebody shed some light on how the quill is removed, what needs to be loosened first? Does the quill lock need to be removed? (this is tight too, even after removing the bolt on the under side) Does the quill pass through the front of the tailstock or out the back?
I have removed the handwheel and the screw thrust plate, the quill is stuck tight I have tried tapping with a rawhide hammer it will move back and forth but is stopped by something
This is holding up a job, so replies would be gratefully received.
