Clock #1
Clock #1
Viewing 25 posts - 1 through 25 (of 28 total)
  • #423071
    David Noble
      @davidnoble71990
      I realise that this must be 'old hat' for many but my first clock TICKS. Lots to do before it is finished but I'm 'quietly' pleased.
      David
      David Noble
        @davidnoble71990
        #423073
        Lainchy
          @lainchy
          Very nice! Well done
          #423075
          Mogens Kilde
            @mogenskilde92996
            a real treat from here – the first continuous ticks must be a milestone – well done!
            #423084
            duncan webster 1
              @duncanwebster1
              Well impressed!
              #423086
              Brian H
                @brianh50089
                It's always exciting when it works! Very well done, that's a real incentive to finish it.
                #423088
                Ian Johnson 1
                  @ianjohnson1
                  It's not 'old hat' to me! It must be really nice to hear the first tick-tock of the clock. Making a clock is on my 'to do' list
                  #423102
                    Congratulations David!
                    David Noble
                      @davidnoble71990
                      Very kind, thank you.
                      David
                      #423117
                      Jeff Dayman
                        @jeffdayman43397
                        Looks great David! well done.
                        #423130
                        Meunier
                          @meunier
                          Looking very good David.
                          Where did you source the construction manual from ?
                          DaveD
                          #423131
                            Only just spotted this thread, David
                            Please let me add my congratulations.
                            David Noble
                              @davidnoble71990
                              Posted by Meunier on 07/08/2019 21:44:08:
                              DaveD
                              Thank you Meunier, I bought it Here
                              David
                              #423137
                              David Noble
                                @davidnoble71990
                                Many thanks are due to Sam who's a member here for all the help with gear calculations.
                                #423144
                                Sam Stones
                                  @samstones42903
                                  You are so welcome David.
                                  It has been a pleasant journey and a privilege to work with you.
                                  I should add that were it not for all the help I got from members of this forum commencing in about 2010, I'd have little if anything to contribute.
                                  All the very best.
                                  Sam
                                  Shivering in cold, cold Melbourne.
                                  #423186
                                  Meunier
                                    @meunier
                                    Posted by David Noble on 07/08/2019 22:24:41:
                                    David
                                    Thanks for the info David, now sorted.
                                    DaveD
                                    #431534
                                    Max Atomic
                                      @maxatomic99232
                                      Looks great good luck with the rest of the construction.
                                      #431560
                                      Bill Pudney
                                        @billpudney37759
                                        Congratulations!! It's my ambition to build a clock, so I am VERY envious of your achievement!!
                                        cheers
                                        Bill
                                        #431567
                                        David Noble
                                          @davidnoble71990
                                          Thank you Max  and Bill
                                          Edited By David Noble on 03/10/2019 08:35:13
                                          #431589
                                          gerry madden
                                            @gerrymadden53711
                                            Nice work Mr N ! And some interesting details there, in particular the pendulum 'hanging by a thread'. I haven't seen this before but might have read about such things. While this 'might' have some advantages over something more conventional, I'm wondering if the thread material is reliable in terms of fatigue. It would be interesting to hear your thoughts.
                                            Gerry
                                            #431607
                                            David Noble
                                              @davidnoble71990
                                              Hello Gerry, that's not just 'thread' that's 'silk thread' !!
                                              It seems that the idea comes from old french clocks. The odd idea appealed to me so I used it.
                                              The thread is suspended from a screw at the top which can turn to adjust the length of swing for fine adjustments.
                                              As for fatigue, I'll let you know!
                                              David
                                              #431615
                                              Bob Stevenson
                                                @bobstevenson13909
                                                I assume that this is the 'Wilding' version of the large wheel skeleton clock, which did indeed have french beginnings. Several members of Epping Forest Horology Club have made it and one of the last people to do so used a rayon filament to set up the finished clock, which would run for about 4 to 5 days. After completely dissassembly no faults or reasons for the poor endurance could be discerned……..
                                                However, after replacing the rayon filament with finest silk embroidery thread the run time suddenly became 12 days!….just one of those fascinating little happenings that keeps horology so seductive for us clock builders.
                                                #431632
                                                David Noble
                                                  @davidnoble71990
                                                  Hello Bob,
                                                  Fascinating indeed. I think I would have used a different word other than 'seductive' !
                                                  David
                                                  #431704
                                                  Sam Stones
                                                    @samstones42903
                                                    Thus 'seduced' by the idea that the finest silk resolved the problem attributed to rayon , would anyone in the EFHC care to repeat the test with rayon (filament), thus dispelling my thoughts that some other effect might have fixed the endurance issue?
                                                    Just curious, Bob.  cheeky
                                                    Personally, I would be concerned for the longevity of rayon versus silk in terms of environmental factors, none the least being UV.
                                                    Here in Australia we have lots of it scattered around. Don't ask me how I know.
                                                    Sam
                                                    Edited By Sam Stones on 04/10/2019 00:00:11
                                                    #431716
                                                      Please forgive the digression, but I thought some members might be interested in this, about Bulle [silk ribbon] Suspension: **LINK**
                                                      http://www.horologix.com/bu005_1.html
