Citric acid or sulfuric acid
Home Forums Locomotives Citric acid or sulfuric acid
  • #1346
    Ron Hancock
      @ronhancock63652
      cleaning copper boiler for welding
      Ron Hancock
        @ronhancock63652
        Hi does anyone know if their is much difference cleaning a boiler ready to weld using Citric acid or sulfuric Acid.
        Mine is clean in most places but some area's difficult to get at are black.
        Some of our club members recommend sulfuric acid as supposed to be a lot better.
        What are your opinions as i can get either but at moment using the Citric Acid
        Ron
        #172152
        John Baguley
          @johnbaguley78655
          I much prefer sulphuric acid as I do find it does a better job and quicker. I do use citric as well though but mainly for cleaning injectors and fittings.
          Ron Hancock
            @ronhancock63652
            Thank you John i will try it i took 5 Gallon to our Club as i was worried about Grandchildren we have a safe area their.
            It is diluted 50 50 what is the best mix or better to use as strong as Possible.
            What do you recomend please.
            #172156
            FMES
              @fmes
              Hi Ron, between 5% and 10% is normally recommended for Sulphuric Acid pickles, acid added to water, never the other way round.
              This is much weaker than battery acid which is around 30%.
              #172158
              Ron Hancock
                @ronhancock63652
                Thank you also glad you said add acid to water
                Will take it to club and dip it
                #173599
                Larry Coleman 1
                  @larrycoleman1
                  Ron
                  Have you thought about bead blasting the areas effected.
                  Larry Coleman
                Home Forums Locomotives Topics
