Are you sure it includes the rotary table. Yes, in the pics but not in the description? Are you sure it includes the rotary table. Yes, in the pics but not in the description?
Seller's description has terminology issues, but I read it as including everything as shown in the pictures :
"Warco minor Mill/Drill, 1hp motor 240V. good condition, comes with stand which can be unbolted and some extra bits. Clamping kit, vice, some cutters, drill chuck, no drill bits, rotary dividing vice, tool holder."
Andrew – if that is too big, then the smaller bench top machines are really your only option & you will have to operate within their power / rigidity limts, both of which will be a lot lower than a modest "Minor" type mill/drill.
If you can find one, an Emco FB2 bench mill (or clone – various sellers sold Taiwanese or PRC copies a few years ago) is a better bet than the modern variants IMO. Still a 120kg machine though. I have a clone ("Ajax" base & table with a "Denford" column & head) & won't be changing it any time soon. I wouldn't bother with a Chester Champion – which I looked to buy before the FB2 came up. Similar base & table design to the FB2, but inferior head & column design, with less rigidity & poor speed range.
Finding the right mix of fit for space, fit for purpose & fit for pocket isn't easy – good luck !
Nigel B
(sorry for the mix of text size & font – can't seem to find away to edit it)
Edited By mgnbuk on 04/01/2020 16:25:29
Edited By JasonB on 04/01/2020 16:44:32
