If you really want to see the real outputs month by month and year on year, have a look at the Navitron forum where monthly results from all sorts of locations in the UK (and with details of orientation, etc) are reported.
750kWh is likely the typical expected annual output per kW installed, for the UK. Differences between summer and winter insolation are well documented. Around 8:1 at a guess. You can check the expected solar production for your particular location, orientation, etc using PVGS data which, over the years, has been proven (or adjusted) to be quite reliable.
Clear cool days in springtime is a good time for PV – good insolation but cool panels. There is no secret that PV panels are good. Just look around at the number of commercial enterprises spring up. So cheap now that for larger installations no subsidy is required – so not like fossil fuels which recive, effectively, billions (costs due to clearing up the mess left behind, lost work time and ill health issues connected with burning fossil fuels for energy.
They are currently planning a one GW solar farm in Australia; plans for connecting North African solar power to Europe are in the pipeline; there are proposals to lay a 1GW HVDC from icelandic geothermal generation and 1.4GW from Norwegan hydro generators. Renewables will replace fossils eventually, so the sooner we all get used to it, the better it will be (without all the naysayers groaning on!).
