Cast Iron Watch Case
Home Forums Clocks and Scientific Instruments Cast Iron Watch Case
Viewing 21 posts - 1 through 21 (of 21 total)
  • #3866
    Steve Crow
      @stevecrow46066
      Steve Crow
        @stevecrow46066
        I need to pick your collective brains.
        Can anyone think of a good reason why bar stock Meehanite wouldn't be a suitable material for a watch case?
        Steve
        #444357
        Emgee
          @emgee
          It rusts and is going to heavy as very thin sections would probably not be strong enough.
          Emgee
          #444358
          Weary
            @weary
            The graphite that Meehanite contains will leave black marks upon contact and when handled.
            #444364
              Posted by Steve Crow on 02/01/2020 18:17:22:
              Steve
              To be honest, Steve : I’m struggling to think of a single reason why it would be a suitable material for a watch case.
              … What type and size of case are you considering ?
              Edited By Michael Gilligan on 02/01/2020 19:16:18
              #444367
              old mart
                @oldmart
                I thought it was the second of January, not April the first, I must go and make a set of cutlery out of that beryllium copper in the shed.angel
                #444380
                blowlamp
                  @blowlamp
                  Bronze would be OK and is already used by some makers if you're looking for a change from stainless steel.
                  Martin.
                  #444399
                  Steve Crow
                    @stevecrow46066
                    Ok, point taken. Back to the drawing board.
                    Incidentally, I was thinking of a squarish pocket watch case – blasted finish. No part of the case touching the movement or crystal.
                    Thank you for the non-frivolous answers
                    #444406
                    Bazyle
                      @bazyle
                      Why think of CI and not plain steel plated?
                      #444424
                      Roderick Jenkins
                        @roderickjenkins93242
                        One of the TV auction shows recently had a pocket watch with a blued steel case that went for a nice price because of its rarity.
                        Rod
                        #444496
                        Steve Crow
                          @stevecrow46066
                          Posted by Bazyle on 02/01/2020 23:29:44:
                          Just thinking out loud really.
                          I was looking for something unusual but easily obtainable and machinable for a pocket watch case.
                          As somebody suggested bronze might work but which grade? Or gunmetal?
                          Any suggestions for other materials would be welcome (except beryllium copper!)
                          #444509
                          Mike Poole
                            @mikepoole82104
                            I suppose the classic materials like gold, silver, stainless steel etc. Have stood the test of time. A wrist watch is going to have to survive sweat on a hot day and that can be pretty corrosive. A pocket watch will also be handled on a regular basis and the sweaty mits problem will be there. Plating can be used to improve the resistance of baser metals as well as decorative effect. Nickel affects some people adversely so may not be a good idea. Titanium can be very attractive but is not exactly cheap.
                            #444538
                            blowlamp
                              @blowlamp
                              I don't know which grade of bronze they use for the case, but I think stainless steel, titanium or sapphire casebacks are normally fitted to minimise skin contact
                              Martin.
                              Zenith Pilot
                              IWC Pilot
                              #444543
                              Oily Rag
                                @oilyrag
                                If you don't want Berylium copper how about AlBeMet??
                                #444624
                                  I think something like figured granite, agate or quartz, if it's not too brittle, would make a pretty amazing case.
                                  <edit> someone got there first:
                                  Edited By Neil Wyatt on 04/01/2020 14:35:54
                                  #444627
                                  ega
                                    @ega
                                    Titanium is also fashionable for wedding rings (but often presents difficulty in machining).
                                    #444630
                                    Raymond Anderson
                                      @raymondanderson34407
                                      If you are looking for something out of the ordinary what about Inconel either 600 or 718. or even Rene 41 , Udimet, all are Heat resisting super alloys [ although that's not a requirement for a watch laugh] but it would be "Unusual "
                                      #444635
                                      Ed Duffner
                                        @edduffner79357
                                        Anodised aluminium, exotic hardwoods, animal horn perhaps. Maybee even some ordinary aluminium with an inlay of another material – e.g. abelone against the wearer's skin ??? What about plastics? Delrin, 3D printed resin or powder deposit, not sure what it's called.
                                        The possibilities seem endless
                                        Ed.
                                        #444646
                                        Brian G
                                          @briang
                                          Pattern welded Damascus steel would look attractive, or perhaps layers of different coloured metals (brass and nickel silver sheets soldered together?) machined to give a rainbow effect similar to the caps on some Parker 61 pens. Something totally impractical and difficult to machine, but I suspect very inviting to the steampunk fraternity, might be corten steel, left outside to weather before fitting the movement.
                                          Brian G
                                          #444659
                                          Adam Phillips
                                            @adamphillips50363
                                            Damascus Steel would get my vote. If you really want to get interesting try meteorite if you can find one. There are a few watches shown on Instagram made of it
                                            Good luck Adam
                                            #444747
                                            Steve Crow
                                              @stevecrow46066
                                              Thank you for some very interesting suggestions, love the corten steel idea. I had to spend a bit of time on google to find out about some of the more exotic suggestions though.
                                              Again, it comes down to availability (and cost!) in a suitable size billet and machineability.
                                              Damscus steel is very interesting and easily available. groundflatstock.com have a beautiful and bewildering array of damascus. I'm not sure about machining it though – surely every batch is different and therefore unpredictable?
                                              As this is a pocket watch and not touching any ones skin, wouldn't a material like aluminium be acceptable?
                                              Steve
