£85 for a turret casting kit! Wish hemingway had that sort of pricing. Might buy the plans for one of the turrets for reference.
steamdave
Was about to send that link to niel but saw you found him. 😛
The angled turret sounds like what the Pultra 1590 turret is.
The angled turret sounds like it is gonna be harder to make but I hadn't thought of the benefits of taking thrust better which does make sense. Having the cut off slide on the turret sounds weird but kind of interesting. One day I might stop mooching off the forums and actually buy a subscription and check it out.
Micheal
Not actually sure if its going to be that expensive. Already had to set aside £85 for all the bearings in the machine which I bet could double if I could find a non B2B supplier for precision bearings on the headstock. Another £100 for motor and vfd. Leaves me £250 before I am equal to the cheapest warco lathe so depends how much material I can get from scrap I guess.
How many melted cast iron brake drums does it take to cast a lathe? We shall find out soon. Once I have the CAD done I will probably make a build thread.
It wasn't even meant to get so big, being built around a high speed er16 spindle which would probably better suit a 1750 or 1770 better. I am just not very good at designing compact cross slides to fit small lathes.
