Hi all,
None of the chucks I have (all of which came with the lathes/pillar drill) are any good. However, I am not too worried as I have decided to buy machine drills, with MT shanks, as and when I need them, to be as accurate as possible and because I find them quick and convenient.
However, where this plan slightly falls down is with centre drills, which obviously need holding somehow. Can anyone recommend a good quality, small (I find many of my chucks way too big for the small MT1 tailstock of the Drummond – an certainly too big for centre drills) good quality chuck that I can use for them? In all likely hood I will just keep a centre drill in place, as a dedicate holder. Obviously it needs to be accurate, which I tend to find many aren't (mainly second hand ones), but doesn't need to be keyless.
I did think I could actually make a centre drill holder, using a tight fitting bore on a MT1 taper, with a retaining screw. Anyone tried anything similar?
Many thanks,
James
