Ok, so firstly, I know many views are quite subjective, and I've also had a look through some of the forum history also.
However, I want to get/buy a lathe. I have access to a large Warco lathe in a community center I visit, but wanted something for home. Also, the warco is very large, so I've had a wee bit of trouble getting some of the tiny parts needed for my kits into it and setup properly. (I'm working on fixing this also, so this is not my main reason for buying a lathe!)
I do not have access to a mill as yet, but the community center are investigating getting one.
What I build:
So far… not much. A Stuart 10V. My next project will be a steam water pump, a larger Stuart engine (Beam or Twin Victoria), maybe a tiny boiler, and some fittings / decorations for in my house. I am not too concerned about spinning huge flywheels for a traction engine, (yet) and have access to the large Warco for that anyway.
I have a range of 12mm carbide tools, and various cutters for brass, alu, steel and stainless.
The Myford Super 7 seems hugely praised in the UK. Less so in the US.
I have found a Super7 from around late 1950s for ~£1000. I cannot tell from the pics if it is a Mk1 or Mk2. It looks in pretty good condition, however, I've not yet viewed it as I am in Ireland and it is in the UK. From what I can tell, it is a basic Super7, with no quick-change gearbox, and no power crossfeed etc. If it was in ok-good condition, would that be a reasonable price?
There are various ML7's and ML7R's available for a similar price, and also Super7's for anything from 900-2500.
I am keen to understand as much as I can before paying for a bunch of repeat visits to the UK, and ferries, etc.
I guess my questions are:
- Super7 seems way more expensive than a ML7 of similar era. Main advantages seem to be the bearings, and also the ability for a power cross slide. Am I missing anything
- Would a S7 Mk1 be a bad choice to buy for my current needs mentioned above? I hear you can upgrade a S7 mk1 to a mk2, but it requires a full new headstock. How could I tell if this has been done other than asking the owner?
- Did the Super7 always have the logo embossed into the belt housing lid? Several units for sale online seem to just have a metal plaque stating Super7 and some spindle speeds, which seems suspect!
- If I was viewing a lathe, what would you recommend checking? I am shooting in the dark other than paintwork, and scratches/chips etc. What are the core must-check things when looking at a 2nd hand lathe?
- Is there anything significant about the paint colour? I had heard that the gray was the original 1950s-1970s colour, then green was the later models, then the new aqua (i think the call it) is the latest 2000 onwards?? One of the lathes I am looking at is white. I am guessing this is a custom paint job. Would this ring any alarm bells with you? (e.g. painted to hide something) Also, the white one (or any of the ones ~£1000) include the quick change gearbox. If i was to retrofit one, this would look silly as i doubt i'd find a white one!
Have I missed anything obvious?
Kindest Regards,
Delalio
Edited By Del Greco on 22/07/2019 13:45:26
