Hi Ian, I run my Bridgeport 2J Varispeed through a Transwave 2 kw static inverter – the sort that has a 415 volt 3-phase socket on it. These produce two good and one ‘phantom’ phase. This works a treat as you don’t have to alter much of the Bridgie wiring. The only change I had to make was to rewire the reversing switch so that the switching was on the ‘good’ phases, not on the phantom phase. Then I just plugged in using the 3-phase plug already fitted to the mill and off we went – although I did have to swap wires in the reversing switch again to get the correct rotation to match the original.
My machine has a suds pump although i have never used it. The pump spins when powered up so presumably it’s OK. The other benefit for me was that the X and Y table power feeds worked without any fiddling.
If you want any more info, feel free to PM me.
Regards, Hugh
