Frank,
Don't want to appear negative but do you need it ?
Reason I ask is I have had 3 Bridgies and currently got a Warco WM40 clone. All three of the bridgies either didn't work, work correctly or broke very soon after being repaired causing me to just stop using the feed.
The book specifies that it should not be used for drilling anything greater than a 3/8" drill which is a joke. They say it's just for fine feeding when boring.
Over the years and I do a lot of bearing housing boring I have replaced the lever quill feed with a large handle and because of the circular handle I can feed at what ever rate I need and still get a good finish.
The WM40 works OK as it should being nearly new but again I don't use it.
I know of a few people, John Moore, Bogstandard is one, who uses one of the Align power feeds on the knee and uses this instead of the quill.
Edited By John Stevenson on 19/10/2014 17:57:33
