OK, I get the waterproof but vapour permeable membrane. Maybe the key item is the air gaps – can't see any point in say, outside to inside, wooden wall, vapour permeable membrane, insulation, maybe poly sheet, and then internal wooden wall all sandwiched directly together?
So for my new shed/workshop, currently a shell:
– 20mm T+G (vertical) with external strips over joins for the wall, 2" thick internal bracing horizontal
– 13mm T+G roof with corrugated bitumen tiles, 2" bracing everywhere internally
– 20mm T+G floor on 2" stretchers sitting on slabs with only the corners mortared (so any really wet will fall through the cracks)
– with the slabs spotted onto a concrete base, so there's an escape route for the wet going between the slabs.
…what does the collective think I should have, outside to inside, including air gaps (and how do I get them?), for the walls and ceiling. In simple, unambiguous, words please!
I'm wanting smooth internal walls (WBP ply or ply, preferably, rather than chipboard or OSB) and willing to lose a bit of space by having thicker walls/ceiling.
(…and sorry for the massive thread hijack – will start a new thread if not acceptable)
