Brazing carbide tips
Home Forums Workshop Tools and Tooling Brazing carbide tips
  • #376623
    michael lennon
      @michaellennon12510
      How do you braze carbide tips for lathe tools?
      michael lennon
        @michaellennon12510
        #376631
        Involute Curve
          @involutecurve
          I use gas welding kit and sifbronze No1, but pretty much any brazing rod will do and you could prbably get away with Map gas if its a small tool and tip.
          #376633
          Ian S C
            @iansc
            I just use LPG, and what ever rod that comes to hand, I have used brass. I now have access to LPG and oxygen and will use that in future if I need it.
            Ian S C
            #376635
            Simon Williams 3
              @simonwilliams3
              +1 from me for Sifbronze, though silver solder will also work, but not always. It seems there are some grades of carbide the flux won't wet, so the solder/braze won't run on to the insert. You just have to find a different grade of insert, though it might now be possible to use some of the more active fluxes and get a better result with these difficult examples. I've only tried doing this with J & M easyflo no 1 which is a pretty benign flux, and intolerant of dirt or funny oxides, so it isn't 100% guaranteed to work. I don't know the science behind this but you can certainly get good adhesion with most insert materials. If it works at all it'll be a good job.
              I'm guessing, though I haven't tried the experiment, that coated inserts may also cause problems in getting the flux to wet them.
              #376642
              Brian Wood
                @brianwood45127
                Simon,
                Coated inserts are no problem, just use the proper Sifbronze flux and rods
                #376922
                Keith Hale
                  @keithhale68713
                  Hi Michael.
                  See personal message.
                  Keith
                  Edited By CuP Alloys 1 on 21/10/2018 11:44:27
