Boxford 280
Boxford 280
Home Forums General Questions Boxford 280
  • #436947
    Andy Sproule
      @andysproule22368
      Hi,I have one of these lathes both power feeds are working and lathe is in as new condition tried everything I can see but can't get the screw cutting to engage.What am I missing?
      Andy Sproule
        @andysproule22368
        #436958
          Should be able to engage it by using the horizontal lever to the right of the apron, not the one to engage feeds
          #436959
          Emgee
            @emgee
            Hi Andy, go to the link below and join the Boxford forum, you may even find a manual in the Files section.
            https://groups.io/g/BoxfordLathe-UserGroup
            Emgee
            #436960
            Andrew Evans
              @andrewevans67134
              Is the leadscrew turning?
              #436969
              Andy Sproule
                @andysproule22368
                Thanks for replies.Yes the lead screw is turning and I have tried the leaver.Posted question on Yahoo boxford group aswell.It came from a school there wouldn't by any chance be some sort of lock on it?
                #436973
                  Got a feeling that the push/pull feed selector needs to be in the mid position eg so that neither facing or length ways feed can be selected, feed lever down then the other lever should engage the halfnuts while the screw is turning.
                  If feeds are working which you say they are then screw will be turning.
                  Edited By JasonB on 12/11/2019 13:59:44
                  #436982
                  Phil JOHNS
                    @philjohns74870
                    Yes JasonB is correct, I have a simplified operating instruction sheet for that lathe and could PDF you a copy of the relevant pages if you PM me an email address
                    #436986
                    Andy Sproule
                      @andysproule22368
                      PM sent Phil.
                      #437012
                      Andy Sproule
                        @andysproule22368
                        Its sorted folks I was able to look underneath with a mirror and with some very gentle tapping on the slide of the half nut and wiggling the leaver it eventually freed up.Thanks again for all your help.
