You won't true that runout with a reamer. Reamer will follow the existing hole. Correct procedure for using a reamer for precision jobs is to
- Drill the hole to remove metal quickly.
- Bore the hole to establish correct location, concentricity and orientation.
- Ream the hole to achieve final size and finish.
With a precision taper such as a spindle like this, the reamer is best used to remove perhaps the last thou of material, about one or two turns with a hand reamer, just enough to remove the highspots from the boring tool marks on the job.
Spindles like this are best made where the OD and the taper are machined in one set-up on a lathe that is known to turn parallel within a few tenths of a thou at least. IE in a large lathe where the large chuck will hold the spindle raw material by one end while the full length is machined to diameter and then the taper drilled and bored and finish reamed.
If you only have a smaller lathe, one way is to machine the female taper in the spindle, then machine an arbor between centres with a male taper on it. The spindle is then mounted on the arbor and the OD turned to size. You may be able to use this method to remachine the OD of your spindle now, so that the OD is concentric with the taper. YOu would then have to fit and machine sleeves to bring the OD back to size to fit your bearings.
Edited By Hopper on 11/02/2018 03:13:39
