Boring copper tube problems
Home Forums General Questions Boring copper tube problems
  • #294122
    nigel jones 5
      @nigeljones5
      I frequently have to bore holes in large bore ( 3 to 6&quot copper tube. I use a stepper drill and then a boring head to go to 1.5". Thing is I am having great difficulty in achieving this as the mill simply doesn't have quite enough torque. My mill is the X2 500w brushed motor. I converted it to belt drive which made things a lot worse as it ups the head speed! I reworked the pulleys to give the lowest gearing I could but the machine still stalls easily. Obvious solution is a bigger mill but I haven't seen anything second hand between mine and a full size Bridgeport type which I simply don't have space for – are there any cutters which would make lighter work of cutting/boring copper using an indexible boring head? I already use milk but it doesn't make much difference.
      nigel jones 5
        @nigeljones5
        #294123
        Neil Lickfold
          @neillickfold44316
          Very sharp tools, small cuts.
          #294134
          Nick_G
            @nick_g
            Posted by fizzy on 19/04/2017 19:55:55:
            I have one of the Boxford ones which has a much smaller foot print than a Bridgeport. – I could measure it for you if needed.
            But that one is IMHO over priced for what they normally go for.
            Nick
            #294137
            Simon Collier
              @simoncollier74340
              This is my Springbok boiler on the table of my SX3. My friends thought I was mad; they simply chain drill and file. I think some use a hole saw.boring boiler bush
              #294140
              ega
                @ega
                Rotabroach?
                #294141
                WorkshopPete
                  @workshoppete
                  Mini Rotabroach I have them up 1 1/2" and the hole is dead size with very little power can be used in a battery drill no need for a mill.
                  #294147
                  Ady1
                    @ady1
                    A lathe with backgear?
                    A lathe is a mill on its back with a fabulously thick column
                    Edited By Ady1 on 20/04/2017 00:43:36
                    #294163
                      I think Nick has the answer if the mill is stalling then you need to reduce the load. You can't reduce the dia so the only other option is to reduce the depth of cut, may take a bit longer making more cuts but you will get there in the end.
                      #294176
                      MW
                        @mw27036
                        I would also use a much sharper HSS tool than the typical carbide brazed boring bar, they're normally far too blunt for the job.
                        Michael W
                        #294188
                        KWIL
                          @kwil
                          The problem with the Boxford VM30 is that it is limited height (ie daylight) once you have a vice and boring head in there. OK for the smaller jobs, if a little noisy with the head gearing.
                          Hence I added a Bridgeport with a raising ring to the machine tool inventory.
                          Chain drilling and then boring to final size is quite easy.
                          Edited By KWIL on 20/04/2017 10:08:42
                          #294202
                          Hopper
                            @hopper
                            Posted by Michael-w on 20/04/2017 09:15:23:
                            Michael W
                            ^^^^ +1 on this. Copper is sticky stuff to machine. A HSS toolbit with a razor sharp honed edge with plenty of top rake works well and plenty of cutting oil to help stop the copper sticking to the toolbit and adding massive drag to the rotation.
                            #294204
                            Roderick Jenkins
                              @roderickjenkins93242
                              I've been using ccgt inserts to machine some copper boiler bits – seems to work very well. Perhaps you can find a holder for your boring head to take this type of insert.
                              Rod
                              #294207
                              Nick_G
                                @nick_g
                                Posted by KWIL on 20/04/2017 10:05:04:
                                I take your point that it is a a little short on headroom for a machine of it's size. Gears on mine are very quiet though.
                                Nick
                                #294216
                                  Hi Fizzy,
                                  I've tuned into the mill stalling part of the story. Perhaps copper, of which I know little, really is that sticky, but I'm suspicious that it's stalling a boring head rather than tearing.
                                  Can you describe your pulley set-up in more detail please? I'm wondering if the ratios are still too high.
                                  As to milk and copper, I'd never heard of that before. On the web someone said "lots of milk", though. I think he means flood rather than dribble if that helps.
                                    Full fat milk for best results. Don't think I would want to flood too much as if you don't clean it all up the workshop will soon stink. I jast dab a bit on with a brush.
                                    #294247
                                      Are you people seriously advocating the use of Milk [as sometimes used in Tea & on CornFlakes] question
                                      … I seem to recall "milk" being a colloquial term for 'soluble cutting oil mixed with water'.
                                      Edit: … and I've just found this
                                      http://mamaflinter.tripod.com/id10.html
                                      Edited By Michael Gilligan on 20/04/2017 15:01:59
                                      #294254
                                      Mikelkie
                                        @mikelkie
                                        I've used cream mixed with meths 50/50 on copper turning with exilent results… a tip from the late Arthur Presscot.
                                        #294258
                                          Yes COW milk Michael and bacon fat for metal spinning.
                                          #294265
                                          Martin Connelly
                                            @martinconnelly55370
                                            I've found rendered pig fat in the form of lard the best lube for rise and fall brass door hinges. I tried all sorts of other thing before lard but none worked as well.
                                            Martin C
                                            #294277
                                              Posted by Mikelkie on 20/04/2017 15:54:00:
                                              Thanks for the confirmation, Mike [and Jason]
                                              nigel jones 5
                                                @nigeljones5
                                                Thankjs one and all…I cant make the cuts any finer at one thou per cut, I cant reduce the gearing amy lower and although the milk helps the stench is terrible next day…more torque me thinks
