Boring bar/head
Boring bar/head
Home Forums General Questions Boring bar/head
Viewing 25 posts - 1 through 25 (of 67 total)
  • #292511
    petro1head
      @petro1head
      I have been given a job to bore some 45mm holes.
      So was thinking about this boring bar **LINK**
      Is this a good cjoice or should I be looking at something else?
      petro1head
        @petro1head
        #292512
        Chris Evans 6
          @chrisevans6
          No reason why it should not do the job, I use a nice French made 4" boring and facing head on my Bridgeport but there is no change out of £300 or more if buying new. Your chosen head will no doubt last you a lifetime.
          #292520
          Speedy Builder5
            @speedybuilder5
            I have one, it works straight out of the box. I think the smallest bore size with the bits supplied is about 10mm dia, but if you ground your own, then they could be smaller.
            BobH
            #292522
            Emgee
              @emgee
              I advise you to get the metric version so you have the finer adjustment.
              Emgee
              #292526
              John Hinkley
                @johnhinkley26699
                Petro1head,
                One of my boring heads is exactly the same as the one in your link and I consider it a perfectly acceptable bit of kit. I've never been able to achieve what I think is a "decent" finish with those carbide tipped tools, though, but I suspect that's more down to my inexperience or incompetence. If you want a super-fine finish, I would encourage you to invest in an insert-type boring tool or a named hss tool. I have a small Sandvik hss boring tool, which gives excellent results, without too much practice.
                Bazyle
                  @bazyle
                  Note the boring tools seem to be out of stock. These ones with interchangeable shanks are much better for the hobbyist who might change machines. Mine is fixed but luckily the same on both mill and lathe but if I ever got an R8 machine it would add to my retooling costs.
                  #292534
                  Nick_G
                    @nick_g
                    Posted by Bazyle on 08/04/2017 11:30:59:
                    Agreed. yes
                    They can then also be used in a lathe tailstock as a poor mans taper turning attachment if light cuts are made.
                    Nick
                    #292537
                    petro1head
                      @petro1head
                      Cheers for the replies. I was going to buy the metric version
                      So are you saying the tools that come with that bar are not the best?
                      I cant see any other boring tools on the ARC website.  Looking elsewhere I see you can get indexable tools.  What about HSS?
                      Edited By petro1head on 08/04/2017 13:13:43
                      #292541
                      John Haine
                        @johnhaine32865
                        I have an 8mm shank HSS tool that came I think from RDG. I use it in my small Arrand boring head. But I also get reasonable results using the standard carbide brazed tools as available from Arc. You need to fiddle round a bit with the rake setting.
                        #292542
                        petro1head
                          @petro1head
                          Posted by John Haine on 08/04/2017 13:27:17:
                          Being new to boring heads can you expand on this please
                          #292547
                          Bruce Voelkerding
                            @brucevoelkerding91659
                            I was given a Boring Head with a set of Boring Tools from a local Machine Shop. It was given to me because " I don't know what's wrong, it chatters". I traced the chatter down to the R8 Shank was undersize. I replaced the R8 Shank and it works very well.
                            The set of Boring Bars I received look like the picture in the Arc-Euro ad – the shanks are plain diameters with no flats. At first I thought to put flats on the Boring Bar shanks so the set screws would not cause dings in the shanks which would make it horrible to remove the m from the Head. Then I realized there was no way to put the Boring Bar in the Head and assure the cutting surface was parallel with the Head motion (as mentioned by John Haine above). I did put flats on the shanks, but the solution was to measure the shank diameter of the Boring Bars. I then put each Boring Bar in the Mill Vice horizontal and rotated the Boring Bar axially until the cutting face of the Carbide was exactly 1/2 the diameter of the shank diameter below the top of the shank (easy to do with a Dial Indicator). I then milled a flat along the shank to a width equal to the set screw size. I can now place a Boring Bar in the Boring Head and slightly jiggle it as I tighten the set screws and it is always aligned correctly. Plus the dings do not prevent the Boring Bar from sliding out freely.
                            Of course the Boring Head in a Mill is only as good as the clearance in the Quill (unless you lock the Quill and feed using the Knee).
                            Another one of those "I did it quicker than the time it took to write this project".
                            Bruce, Cleveland, Ohio
                            #292562
                            John Hinkley
                              @johnhinkley26699
                              Just to clarify – I wasn't suggesting in my post above that the supplied boring bars weren't any good [Arc wouldn't sell them if that was the case], just that I couldn't get a good finish with them. Oh, and I didn't get my boring head and bars from Arc, so maybe I'm comparing apples with pears.
                              mechman48
                                @mechman48
                                Snap! have a set like that but came in the plastic carry box used it once so far… can't remember what tho' ( see other thread about losing memory face 20​ ) mine is metric too, IIRC I titivated the point to a fine radius with a diamond lap & it gave an acceptable finish, worth the spend.
                                George.
                                #292578
                                John Haine
                                  @johnhaine32865
                                  Posted by petro1head on 08/04/2017 13:32:53:
                                  See Bruce's reply above.
                                  #292582
                                  not done it yet
                                    @notdoneityet
                                    I now always look very sceptically at offers with several 'cutters' along with the basic tool. Often, one decent quality cutter, bought separately, exceeds the 'assumed' value of the 'offer pack' where one does not need all the 'specials' (or even all but one!).
                                    I have, before now, thought 'If only I had not bought that '***' item, as I will likely never use it…' Or if I need one, I would buy a better quality one than the one on offer. Special offers are not always what they immediately appear to be cracked up as!
                                    #292586
                                    Muzzer
                                      @muzzer
                                      Regardless of whether these particular examples are good quality or not, their basic tool geometry is rather crude. An indexable boring bar offers the benefits of higher top rake and chip breaker, resulting in lower cutting forces and likely better finish. Spend a little more and you can get something like this. The ground finish inserts (**GT) are good for small machines and are fine for steel unless you are taking very heavy (by our standards) cuts.
                                      Murray
                                      Edited By Neil Wyatt on 09/04/2017 08:35:25
                                      #292592
                                      Jon
                                        @jon
                                        Have used for decades the cheap brazed on carbide in first link all made by same company, however they will need reprofiling and sharpening sold as steel or cast iron.
                                        Mainly used on aluminiums they don't generally leave a respectable finish on most steels due to the flex. More you try to correct the worse it gets often showing up as chaff marks.
                                        One respectable strong boring bar would be 4 times the price as the carousel.
                                        #292597
                                        ronan walsh
                                          @ronanwalsh98054
                                          I don't think it matters what a boring head is, metric or imperial, as i always use a DTI for adjustments, its easy and gawd knows what the divisions are on some of these far-eastern made heads. The cheapo bars that come with them are very roughly made, i have a set and all the tips were at different angles to each other, very sloppily brazed on.
                                          A trick i was shown before, and works very well if the holes aren't too deep, is to use a slot drill in the boring head, with the point/corner as the cutting edge, before you pooh-pooh it, try it.
                                          #292598
                                          petro1head
                                            @petro1head
                                            The job I am doing needs to have a good finish so where do I buy decent cutters. I machining Aluminium
                                            #292601
                                            ronan walsh
                                              @ronanwalsh98054
                                              Use an indexable lathe boring bar the same size shank as the holes in your boring head. For aluminium i would try a tip with a radius rather than a sharp point though.
                                              #292615
                                              petro1head
                                                @petro1head
                                                Posted by ronan walsh on 09/04/2017 01:43:51:
                                                From what I can see, looking at the ARC web site, all the tips they sell have a radius.
                                                If I use a lather boring bar will I not have to shorten it?
                                                #292624
                                                Chris Evans 6
                                                  @chrisevans6
                                                  I always use the shortest possible bar that will do the job, I have a set of 3/4" shank brazed carbide tip boring bars all cut well with a bit of playing round with geometry of cutting edges. For most of my boring jobs though I use home made bars with bits of HSS held in with a grub screw. Some of these have the hole for the tool bit put in at 45 degrees to enable cutting into blind corners, others are just a simple cross hole for through holes. Many years ago whilst an apprentice I was spoilt using Genevoise (spelling?) boring machines and Whalupta (Spelling?) boring heads. The three months working on the boring machines including horizontal and vertical borers taught me the way to grind the boring bit.
                                                  #292625
                                                    Chronos do a nice little set of 3 indexable bars made for these heads and that is what I use most of the time, they do have radiused corners to the triangular inserts but I get a good finish in both steel and ali. They have flats for the grub screw so they fit at the correct angle. Top of this page. I think RDG do them in metric shanks but I don't buy much from them.
                                                    Also get on OK with a set of 9 similar brazed tools, 3 or 4 are more or less as is for boring to different lengths, a couple modified for external machining, one ground to cut chamfers on the edge of holes or spogots, another to radius internal and external corners and teh last couple ground down for small hole boring.
                                                    Finish in ali
                                                    Press fit for 10mm OD beraing
                                                    Holes from 10mm to 36mm
                                                    #292636
                                                    petro1head
                                                      @petro1head
                                                      Those look perfect Jason but only seem to do 1/2", I would need 12mm
                                                      Had a look at RDG Tools and all I could find was this – **LINK** or **LINK**
                                                      Not sure which would be best?
