Boiler hydraulic test 4 hours
Home Forums Stationary engines Boiler hydraulic test 4 hours
Viewing 10 posts - 26 through 35 (of 35 total)
  • #811325
    cogdobbler
      @cogdobbler
      Looks like a lovely little unit and should make the basis for a nice steam plant.
      It is what, in industry, would be called an underfired single-pass firetube boiler. Quite a popular design in the mid 20th century. I’m old enough that I worked on several full sized versions over the years.
      endckr111
        @endckr111
        Yes, it’s an interesting design, nice to know someone who actually worked on them! The more I uncover, the more questions I have! It will be nice to get it steaming one day, still a fair amount of work to do, new fittings ect, and still wondering about insulation and firebox lining material which extends to boiler sides, easier to see once covers removed
        #811329
        endckr111
          @endckr111
          One side removed revealing fireboxIMG_1783IMG_1784IMG_1785
          #811335
          endckr111
            @endckr111
            <p style=”text-align: center;”>Just noticed the water level take off from boiler, that doesn’t looked-bushed but silver soldered directly, maybe it’s stepped down and soldered? Is it worth drilling out and bushing?</p>
            #811341
              Probably more trouble than it is worth. There is a risk of melting other joints as you try and solder in a new bush which may then be hard to rectify.
              #811350
              endckr111
                @endckr111
                <p style=”text-align: left;”>Well, I’ve disassembled it, taking precautions! A lot of very small screws holding everything together, which I will replace. As you can from photos boiler looks ok, and there’s two silver soldered extension (not sure if it’s a brazed or silver soldered that goes for all the boiler)IMG_1792IMG_1789IMG_1791IMG_1788IMG_1790one each side, and as pointed out I think best to leave them in place, one I think will be for hand pump , the other possibly an injector. The main manifold which needs to support pressure gauge and blower, and water gauge top fitting,needs replacing, so I will look around for some suitable fitting, first job, blanking plugs ect!</p>
                #811351
                noel shelley
                  @noelshelley55608
                  When it comes to sealing all the various joints and suchlike Air Setting cement of the type used in pottery kilns will be ideal Alec Tiranti  used to supply. Good luck. Noel.
                  #811364
                  Nigel Graham 2
                    @nigelgraham2
                    The gauge-glass fitting in the side looks to me as if screwed, possibly soldered, into a bush that itself is silver-soldered into the shell.
                    I’d be inclined to leave that alone. It obviously withstood the hydraulic test, although it is not in the best position functionally.
                    The gauge-glass fitting itself though should have a simple blow-down valve below the lower glass elbow, to flush the glass through and ensure it is working.
                    #811366
                    endckr111
                      @endckr111
                      I agree with you Nigel, not worth the hassle re-bushing, and as you say, if it past hydraulic test, then leave be. Also agree with gauge glass blow down valve, that should be an easy fix!.
                      #811528
                      noel shelley
                        @noelshelley55608
                        While the pressure vessel may be professionally built, though I doubt it but the welding of the firebox and casing is definitely not. It’s inside so not important. An interesting boiler that will do credit to a working steam plant. Good Luck. Noel.
                      Home Forums Stationary engines Topics
