I am housebound at the moment with a nasty bout of sciatica. Having nothing better to do, I started thinking of sharpening some blunt hand reamers. If you have the right kit, this is a not a difficult job. BUT the reamer will finish up a thou or two undersize.
I started to consider my machine reamers, now these can easily be sharpened, and as the cutting edge is at the front of the reamer. You finish up with the original diameter.
So why not regrind the hand reamers in the same manner? OK these are plain shanks and you will need to make a MT adapter for machine use. Maybe not quite so easy to get everything in alignment. However if you have a self aligning reamer attachment, then any alignment errors do not matter.
Sounds a great way of saving your blunt reamer. There must be a snag somewhere otherwise the idea would have been hit upon before now! So where am I going wrong?
Andrew.
Edited By Andrew Tinsley on 15/08/2017 16:08:04
