Blower pipe V blower ring.
Home › Forums › Locomotives › Blower pipe V blower ring.
  • #418885
    Half centre
      @halfcentre
      I have noticed how some locos have a simple blower pipe (mine included), others a blower ring. I was wondering what the advantages and disadvantages of the two systems are? A few random thoughts come to mind.
      Pipe is relatively easy to build?
      Ring truer to prototype?
      Pipe less prone to blockages (wider nozzle)?
      Does a ring make more efficient use of steam, do you get more draught from a given steam volume?
      Has anyone substituted one for the other, if so why, and was it an ‘improvement’?
      Looking forward to the forums thoughts
      Martin
      #1842
      Half centre
        @halfcentre
        Ads and disads
        #418908
        Bob Rodgerson
          @bobrodgerson97362
          From what I have seen a slower ring usually has nozzles that can be unscrewed making it easier to experiment with various nozzle sizes.
          #418911
          Simon Collier
            @simoncollier74340
            Like the blast nozzle, you want the blower holes concentric to the chimney so the blower will be more efficient, using less steam, and yes, more draught from a given volume. It is not difficult to make a blower ring with 3 or 4 holes. I use the rotary table and 1 mm holes. Some angle them so they point at the choke of the petticoat which probably also helps. I read an article somewhere on hole sizes in the blower ring and what was optimal but I can't recall where.
            #419058
            Half centre
              @halfcentre
              Many thanks chaps – I think the best thing is to make a ring, perhaps with nozzles which can be swapped and give it a try. Its not at all difficult to go back to the pipe if there is no obvious improvement. I will start with 1mm holes.
              Martin
            Home › Forums › Locomotives › Topics
