Bending 1/8″ Steel Plate
Home Forums Beginners questions Bending 1/8″ Steel Plate
Viewing 9 posts - 26 through 34 (of 34 total)
  • #471884
    Mike Poole
      @mikepoole82104
      If you have silver soldered with it before then it can produce the required temperature but can it produce a large enough amount of heat to get the larger mass to temperature. Conserving the available heat is important if you think the amount of heat may be marginal A surround of insulating blocks like skamolex or vermiculite will keep the heat on the job and not absorb it. What is plan B if you try it and it won’t do the job? Other than having to do another clean up it shouldn’t do any harm to try it, just make sure you can make the best use of the available heat.
      Edited By Mike Poole on 15/05/2020 10:22:59
      Mike Donnerstag
        @mikedonnerstag
        I'm trying to keep costs as low as possible, as this may be a one-off job. Do you think these vermiculite bricks from eBay would be okay for a small hearth (£10 for 5 bricks, delivered):
        Mike Poole
          @mikepoole82104
          That’s the sort of thing I use and they are fine for my occasional use, they are not the most durable things but with care they should give useful service.
          #471919
          Mike Donnerstag
            @mikedonnerstag
            On silver-soldering again, if I am able to get the workpiece(s) up to a dull red heat, is that a good indication that I should be able to silver solder it?
            #471923
            not done it yet
              @notdoneityet
              Even house bricks can do the job – but they will initially absorb a lot of heat, so use a lot more energy for the job, especially with a small burner. Just so much easier and faster with the right kit because they maximise the reflected heat.🙂. Gas is not cheap.
              #471946
              Nicholas Farr
                @nicholasfarr14254
                Hi Mike, it depends on the melting point of your silver solder, of which there is quite a range from low to high. Dull red is about 700 C, cherry red about 800 C and bright red about 900 C, but of course it will depend on one's interpretation of what is dull to what is bright, as we all see colours differently. Best to slowly heat a small piece up and determine exactly what colour your solder melts at, but the whole area of your joint needs to get to that colour at the same time and stay at the colour for the time it take to apply the solder.
                Regards Nick.
                #472155
                Norman Billingham
                  @normanbillingham91454
                  A lot depends on what your silver solder wire actually is. Silver solders come in lots of grades from "extra easy" (mp 670) up to "hard" (mp 760). The normal braze alloy for model engineering is AG455 which melts at 650. If you use that with EF flux it's pretty much self-indicating – the flux will dehydrate to a white, fluffy powder on heating and turn to a clear liquid when the work is hot enough to melt the braze alloy. So apply flux as paste, heat gently till it dehydrates then as strongly as possible until the flux turns clear, then apply the alloy – use the work not the flame to melt the alloy.
                  I'd be very cautious about using house bricks for a hearth – they can contain a fair bit of absorbed water which boils and cause bits of brick to come flying off. The compressed vermiculite blocks are good or you can get proper firebricks very cheaply. With half decent insulation, a MAPP torch should have no problem brazing a job like that.
                  #472170
                  not done it yet
                    @notdoneityet
                    Anything porous containing moisture will spall if heated too strongly until the water has had time to boil and dissipate safely. Gunnnited flues need to be heated carefully to avoid this issue. I think it used to be around 50 degrees Celsius per hour surface temperature, IIRC. But the main problem there was of the whole lot parting company from the supporting steelwork.
                    #472279
                    Henry Brown
                      @henrybrown95529
                      Posted by duncan webster on 12/05/2020 23:14:42:
                      If you've got an electric welder you can carefully saw halfway through on the bend lines ( on the outside) then bend the bar, then run a bead of weld along the now opened up slit. Try it out on a short bit.
                      Thanks for that Duncan, I've just got to the stage of bending a piece of 2mm plate into a W shape and was wondering how I was going to do it, sounds perfect.
