Bench vice hight for modern workshop
Home Forums Workshop Tools and Tooling Bench vice hight for modern workshop
Viewing 15 posts - 1 through 15 (of 15 total)
  • #240259
    Martin Kyte
      @martinkyte99762
      Hi Chaps
      Got to thinking the other day that maybe the old advise about bench vice height is a little out of date. I installed mine with the jaws at elbow height as per normal which is great for traditional filing of flat faces and hack-sawing. Trouble is how much of that gets done these days ? Generating flat surfaces is usually done on the mill and many of us have some kind of cut off saw for chopping up material. This leaves the vise for the fine finishing of small parts with needle files and the like and that's when you need your eyes as close to the work as possible. This would argue for a vice at chest height.
      What does anyone else think or maybe you already have other arrangements.
      regards Martin
      Martin Kyte
        @martinkyte99762
        #240260
        David Jupp
          @davidjupp51506
          Sit on a stool ?
          #240262
            Or have a small toolmakers vice that fits in the big one, that is what I do with small detailed parts.
            #240263
            Mike Poole
              @mikepoole82104
              As Jason says a vice held in the main bench vice can be very useful. The instrument makers type of vice is good for small parts and has great flexibility in holding the part at all sorts of angles. Due to a manufacturing cock up my main vice is about an inch too high. I will make a duckboard to put this right one day, until I do it will continue to irritate me.
              #240270
              Peter Tucker
                @petertucker86088
                Posted by David Jupp on 25/05/2016 16:38:15:
                Sit on a stool ?
                That's what I do,
                Peter.
                #240271
                jimmy b
                  @jimmyb
                  Posted by JasonB on 25/05/2016 16:50:40:
                  I have a very small vice mounted on the end of some 1 1/2" square bar, perfect for them little jobs
                  #240273
                    Martyn,
                    A good rule of thumb is that the average angle at your elbow should be a little more than 90° [obviously this angle will vary during the stroke of a file or saw], and your posture should be reasonably upright.
                    Various tools and activities therefore dictate different heights [as mentioned earlier]
                    To avoid leg and back fatigue it is best to not stand rigidly, and it can be helpful to stand on a flexible mat which induces small movements.
                    P.S. … The 'rump rest' [see fig. 60 here] is an excellent alternative to perching on a stool.
                    Edited By Michael Gilligan on 25/05/2016 18:00:00
                    #240276
                    mechman48
                      @mechman48
                      I sit on a 2 step kitchen stool when I need to do close work, I have a 2" clamp on mini vice in the end of my bench, I use a fold up bar stool if my back arthritis kicks in when I'm using the lathe, I have foam pads on the floor, old stereo system on a shelf, tea caddy & kettle on the tool chest… comfy or what face 23
                      George.
                      #240280
                      Bazyle
                        @bazyle
                        Standing up to work in the office has become the latest fad spawning an industry of overpriced elevating desks and things to put on the desk to raise the computer and then excercisey things to do with your feet while standing. Having spent much of the day standing at work today I was rather glad to get a chance to sit down.
                        Perhaps MEW should publish a design of a steam elevating bench or a variable thickness duckboard to go in front of a high bench. Time to get one together for the April issue.
                        #240282
                          Posted by Bazyle on 25/05/2016 18:31:57:
                          Standing up to work in the office has become the latest fad …
                          Ian Welford
                            @ianwelford58739
                            got a couple of bar stools but comfy chair with large cushion is best for contemplation, coffee, cake etc. I have a magnifying lamp I have got to get round to installing near the workbench but get round to is the operative phrase !
                            Foam mat / old carpet on the floor adds comfort and protection to dropped tools, not that any of you would be as careless of course……
                            #240288
                            not done it yet
                              @notdoneityet
                              One of my vices is dropping the lathe in back gear for removing the chuck. It is also a vice to leave your vise over-tightened for long periods. Another vice might even be that of using both words to cover up one's spelling.smiley
                              As above a lower vise, at elbow height, is the best. One can generally adopt a strategy to make it higher, but unless you have something to temporarily stand on it is not so easy, when too high, to lower it. Mine is too high but lowering the bench is not an easy option.
                              Edited By Richard Balderson on 25/05/2016 19:25:33
                              #240360
                              Dusty
                                @dusty
                                Ian I also have a 'roundtoit' as I suspect have many others on here, the only trouble I find, is, that I never have time to use it. I am a subscriber to the stool clan (why stand when you can sit) I also have on my bench a swivel vice which I find invaluable at times.
                                #240366
                                Ian Welford
                                  @ianwelford58739
                                  Dusty
                                  I'm even more embarrassed to admit _ I too have a swivel vice been maturing under the bench since I moved house ( 18 years ago), it lives next to the "roundtoit". blush
