Belt cover construction
Home › Forums › Manual machine tools › Belt cover construction
  • #403081
    Plasma
      @plasma
      Hi just bough a startrite mercury mk 2 bench drill and it's missing the hinged belt cover.
      Ive seen a few photos but can't tell if it's a thick walled casting or a steel sheet fabrication.
      Does anyone have a similar model they can look at and give ne an answer.
      #13478
      Plasma
        @plasma
        #403088
        DMR
          @dmr
          Hi Plasma,
          I have serial number 66152 which looks identical. You are in fact two pieces short as the cover needs a back support as well on that model. It is sheet steel but I wouldn't have to try and bend it up at the original thickness! It even has turned in edges! Sent you a PM.
          Dennis
