Hello Andrew,
Coarse teeth on a band saw, I use 10 tpi, but switch to 14 if cutting thin walled tubes. as Bazyle says, swarf clearance is the key, fine pitch band saw blades clog and will break.
Bi metal blades are to be recommended, the life is much better as a result. Blade tension should be high, not to musical note level when twanged but at double bass levels.
