backpage key
backpage key
Home Forums General Questions backpage key
Viewing 3 posts - 26 through 28 (of 28 total)
  • #122803
      Posted by Sid Herbage on 21/06/2013 00:43:18:
      I've wondered if some sneaky sites are actually programmed to open twice (or more) in succession when you go to them to deliberately cause this effect. I think that's probably possible and if it can be done, I'm sure someone will do it.
      Sid,
      Have a look here [it's also worth reading the comments]
      … and there is a live demo on the viralpatel blog.
      Edited By Michael Gilligan on 21/06/2013 07:35:38
        Posted by Sid Herbage on 21/06/2013 02:01:58
        (I'd put ' Backspace ' in carets and it disappeared. What a super editor.
        Sid,
        That's because the editor allows the insertion of raw HTML code.
        Here is an example: on the Demo line, I type ABC followed by a series of "backspace in carets"
        Demo: ABC
        … if that works as I think it does, you should see only Demo:
        … but if you "Quote" my posting; then watch the grey strip as you select various parts of my text, you will see the HTML.
        (I hope this works)
        Edit: sorry, the demo didn't quite work, I was hoping it would delete the ABC
        Edited By Michael Gilligan on 21/06/2013 08:04:52
        Edited By Michael Gilligan on 21/06/2013 08:06:48
        #122810
          Posted by Michael Gilligan on 21/06/2013 08:00:37
          I've just realised why that didn't work as expected …
          Backspace is not a valid HTML tag; so "backspace in carets" is treated by the editor as just an empty pair of carets, so it disappears.
