I have an SX2, hated the standard spring and opted for a side mounted gas strut modification, (cost of modification £13.00).
I did not like how most of the centrally mounted ones had been done, and was still undecided on where I was going to mount the Z axis motor as part of the CNC conversion I am still working on, the install still allowed for tilting the column.
I have since replaced the column and base for fixed versions and re-fitted the gas strut to the new column.
I can leave the column unlocked at any height and it will not move (obviously I do not machine with the Z axis unlocked). It also has the same level of resistance throughout the complete travel of the Z axis (unlike the spring) which is usefull for drilling operations.
By the time I have finished converting the mill to CNC, I would probably have been better off simply buying the parts I needed (if they were available) and building from there – I will have almost enough parts left over to make a new mill! – but then I would not have had a machine to make all of the new parts on either.
Edited By Zebethyal on 24/01/2018 11:34:28
