Any idea what this is guys & gals
Home Forums The Tea Room Any idea what this is guys & gals
Viewing 25 posts - 1 through 25 (of 34 total)
  • #492033
    Steviegtr
      @steviegtr
      A friend of mine showed me this today & asked what it might be. It came from a deceased model engineer. I am usually quite good at guessing stuff, but have no idea what this is. I think it may be pneumatic.
      Steve.
      Steviegtr
        @steviegtr
        #492097
        Georgineer
          @georgineer
          It's a grostling iron, model B by the look of it.
          George B.
          #492202
          Steviegtr
            @steviegtr
            What on earth is a grostling iron. If it helps, the smaller one fits inside the larger tube. The larger tube has a disc in the bottom with a row of i think 6 holes around it. I thought it was something to do with air.
            Steve.
            #492212
            Mike Poole
              @mikepoole82104
              I give in, what is it?
              i don’t know what it is but it’s highly likely someone will know
              #492220
              Hopper
                @hopper
                The six holes around the end indicate it is a ventilated grostling iron.
                #492221
                Steviegtr
                  @steviegtr
                  So i guess that all the guys on here that i thought were very clever people are only micro Plebs. MM interesting.
                  One end has a 1/4" fitting & the other a 3/8".
                  Strange how if you don't know you try & BECOME SEMI INTELLIGENT WITH A STUPID COMMENT TO GAIN POINTS
                  I truly have no idea what this is. If asked though i would not say it was a Zebus valve etc. Come on guys someone must have seen one of these before.
                  P.S It is not part of my dads iron lung.
                  Steve.
                  #492222
                  Hopper
                    @hopper
                    #492226
                    derek hall 1
                      @derekhall1
                      I have no idea what it is either.
                      But I know that sometimes humour doesnt travel well occasionally.!
                      For a master class on this try looking on YouTube for "The Turbo Encabulator" ….I found it funny but my daughter did not ….she has a degree in history and doesnt understand "engineery things" and thought it was real …..some of the technical terminology used is wonderful and now a "ventilated grostling iron" can be added to my technical vocabulary!!!
                      Regards to all
                      Derek
                      #492228
                      Daniel
                        @daniel
                        True to form, I spent a while Googling Grostling Iron blush
                        As is usual for me, it took a fair while for the penny to
                        drop.
                        laugh
                        We shouldn't take ourselves too seriously ….
                        ATB,
                        Daniel
                        #492229
                        Brian H
                          @brianh50089
                          Maybe some people find the comments funny but e still have no idea what the items are.
                          #492233
                          derek hall 1
                            @derekhall1
                            It does look like an air tool though, why not connect it to an air supply through a regulator and gradually increase the air pressure see what happens?
                            Derek
                            #492235
                            Ady1
                              @ady1
                              Irony and humour are like art, literature and mathematics
                              Not everyone can do stuff
                              edit, looks like a couple of shock absorbers
                              Edited By Ady1 on 24/08/2020 08:12:43
                              #492240
                              Jon Lawes
                                @jonlawes51698
                                Are the components a snug fit together? Any sign of any valving internally?
                                #492243
                                Hopper
                                  @hopper
                                  Made from stainless steel like that it looks like a piece of surgical equipment.
                                  The fitting on the lower end obviously hooks up to a pump of some sort.
                                  The other, tapered, end with the nozzle was probably inserted into whichever orifice needed surgically flushing out.
                                  That would be my best guess as a former hospital engineer. Or it could have been part of an early rectal endoscopy probe.
                                  Edited By Hopper on 24/08/2020 09:07:51
                                  Edited By Hopper on 24/08/2020 09:11:29
                                  #492249
                                  Mark Simpson 1
                                    @marksimpson1
                                    it has the look of a "surge damper" which are used to smooth air flow. Pulses from piston compressors can travel a long way down pipework if the end process requires a very smooth flow.
                                    could also be a "ventilated grostling iron" I'm no expert
                                    #492250
                                    Roderick Jenkins
                                      @roderickjenkins93242
                                      Posted by Hopper on 24/08/2020 09:06:20
                                      Perhaps it was left behind by a visiting flying saucer wink
                                      Rod
                                      #492253
                                      pgk pgk
                                        @pgkpgk17461
                                        Posted by Hopper on 24/08/2020 09:06:20:
                                        I believe the americans have an expresion of 'blow it out your a**'
                                        Someone's attempt at a damper for an office chair?
                                        pgk
                                        #492264
                                        Brian Oldford
                                          @brianoldford70365
                                          Posted by Roderick Jenkins on 24/08/2020 09:22:12:
                                          Rod
                                          Were you to tell us where it may have been left could be "far too much information" winklaugh
                                          #492265
                                          Ady1
                                            @ady1
                                            oooh the irony
                                            #492268
                                            Hopper
                                              @hopper
                                              Posted by pgk pgk on 24/08/2020 09:29:30:
                                              pgk
                                              Flow control valve?
                                              #492272
                                              V8Eng
                                                @v8eng
                                                Removed by V8.
                                                Edited By V8Eng on 24/08/2020 10:49:46
                                                #492273
                                                Ady1
                                                  @ady1
                                                  edited*
                                                  (6 months with no pub quiz is getting to me)
                                                  Edited By Ady1 on 24/08/2020 10:46:09
                                                  #492277
                                                  Mick B1
                                                    @mickb1
                                                    The open U-shaped cutouts in the collar make it look as it it's intended to be pushed against some sort of pressure valve but not locked to it.
                                                    I think it's far too far down in the assembly Bill Of Materials to guess what the ultimate parent was. For example, many people would recognise the extractor from a QF artillery piece, but what would distinguish the recuperator piston from any other hydraulic piston of similar size?
                                                    Without somebody being able to access specialist knowledge of the device of which it's part, there's no chance.
                                                    #492281
                                                    Brian Sweeting 2
                                                      @briansweeting2
                                                      It looks to me somewhat similar to an air operated "mole" as used by the gas and water trades to drive a pipe through the ground.
