All things Beaver Mill
Home Forums Manual machine tools All things Beaver Mill
Viewing 4 posts - 201 through 204 (of 204 total)
  • #804991
    DC31k
      @dc31k
      I can describe how it works on a PAL (later model). The centre hole is threaded and is what ultimately retains the boss. The boss itself has an oilite bush in it. A top hat washer whose minor diameter is the same as the projecting quill shaft is used. A spring is used between the boss and the brim of the top hat.
      The boss has one projecting pin on it which provides the drive. This, in combination with the spring, allows the handle to be repositioned in 90 degree increments.
      In principle, it operates in the same way as the knee crank handle but with fewer (only four) positions.
      See:
      http://www.vintagemachinery.org/mfgindex/imagedetail.aspx?id=17685
      On my own, I made a new boss and now use a Moore jig borer-style steering wheel (originally from a boat).
      Andrew Skinner
        @andrewskinner94774
        Thanks very much. I assume the quill handle is canted out at some slight angle, say 5deg, to clear the quill feed engagement lever?
        Another small problem is, the Y axis leadscrew is rumbling badly as I turn it. Is it easy enough to strip down, and to find new thrust bearings for it?
        #805105
        Swarf Maker
          @swarfmaker85383
          Hi Andrew Skinner,
          The quill handle is very simple and basic.  I hope these photos help.
          Quill Handle 3Quill Handle 1Quill Handle 2
          #805142
          Andrew Skinner
            @andrewskinner94774
            Thanks swarf maker, the photos do help. Does your quill handle/boss just sit there loose, or have you removed the retaining bolt?
